#13 | |
Re: tbi tuning
Vortec heads will not require as much timing as your original heads and with all other speed goodies that you have no stock bin (EPROM contents) will run your engine properly. Did you update Vortec heads for higher lift???? One point of reference for bin files is Moates.net in the 1227747 $42 section. There are several posted bins there that were developed to run engine combos very similar to yours. With enough fuel and proper tune your combo should be in 300+ HP range. Expect to idle around 700 RPM with a hint of lope. My advise - learn how to burn your own chips or get EBL board from Dynamic EFI which allows real time changes - no chips required. http://www.dynamicefi.com/ EBL makes tuning a much simpler task (I have EBL flash in my C20) well worth it. //RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) ![]() New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
