HELP Lowering a 3/4 ton truck
Can anyone give me some info on a static drop for a 88 extended cab long bed? Whats the difference between 1/2 and 3/4 as far as suspension. I can get a DJM flip kit for the rear but I am having difficulty finding the proper product for the front end eg...coils and spindles. The guy at Summit told me it is the same flip kit for both 1/2 and 3/4 ton trucks. It has 5 leaf in back and 6 lug wheels. Is the front the same as a half ton?
I guess I just don't know the specifics of the rotor size, control arms, etc... Any and all help will be greatly appreciated. Thanks. Doug
Re: HELP Lowering a 3/4 ton truck
Anyone??
The One And Only !!!
Hope you don't mind Doug, I posted your questions in the suspension section.
Someone there may be of help, Sorry I'm not up on the 3/4's..... Good Luck
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
Going back that old, I'm not sure if everything is the same. I know the suspension stuff is the same. The brakes may be different. If it were an 8 lug you wouldn't be able to do much with it. I don't know of anyone that makes a lowering set up for the 8 bolt trucks.
"I'm the only John Wayne left in this town" John Rich&Kenny Alphin 96 K1500 ![]() 99 K1500 Burb (wife's grocery getter)
Thanks for the replies guys. I'll keep lookin. Doug
Cut the front coils for drop in the front?
and out back, remove some leafs out of the pack and make/get some made lowering shackles.... Its just like a half ton suspension but everything is bigger and heavier.
Mine- '91 GMC RCSB 2wd, 350tbi, 5 speed, 3.42 G80 -Dad/Me Projects/Toys 75 SWB Silverado Factory 454, Th400 87 SWB Silverado 305tbi, 700r4, 2.73's...17.4 @74mph a couple dodge cummins trucks. PLEASE DO NOT MESSAGE ME ABOUT FACTORY TACH DASHES, I AM NOT MY FATHER AND I KNOW VERY LITTLE ABOUT THEM. Thanks
| Bookmarks |
