Old 02-03-2009, 03:33 PM   #1
manimal
manimal's Avatar
SUPER EASY pilot bushing removal tip
I am in the process of converting my '69 C10 to automatic from a 3 on the tree. Here is a VERY simple way to remove the pilot bushing WITHOUT the greasy mess.
5/8" tap( I used a fine thread 'cuz thats all I had)threaded all way through
and out it comes...
clean out the shavings,and you're DONE....5 minutes tops.
Good Luck.
-Lance
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 02-03-2009, 04:03 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: SUPER EASY pilot bushing removal tip
Good tip... Most people that work on these old trucks have taps.
Someone here used the same technique using a bolt. That's what I used many years ago but a tap might work better if it's really stuck.
68gmsee is offline   Reply With Quote
Old 02-06-2009, 11:51 PM   #3
manimal
manimal's Avatar
Now I am going to be putting in a new bushing 'cause I decided to keep it manual and eventually get a muncie or T-10.("...oh the drama!" my wife says)
-Lance
-Lance
