02-05-2009, 08:54 PM | #26 |
Active Member
Re: Six cylinder distributor: Points vs HEI (update)
Been a while since I updated last.
To recap, I was trying to see if changing to an HEI distributor would make any difference on my 250 six cylinder performance or mpg. I actually went back and forth a couple of times between points and HEI to do this test. My conlusion: There was no improvement in miles per gallon (I may need to play with adjustments a little more). BUT, I did noticed an improvement in performance! As Longhorn man and others mentioned, throttle response, idling, etc. would be better so I paid particular attention to these and notice an improvement there. Especially when going at lower speeds in high gear and on the freeway. I think my next move is to get a good aftermarket one and hold on to my point distributor as a backup. |
02-06-2009, 02:42 AM | #27 | |
I had a V-8
Anyways, the one thing that I would HIGHLY recommend trying is to get a Moroso p/n 72300 curve kit. It comes with weights and several springs. I used one light spring and one medium spring and it worked fantastic. I never put a timing light on it, I just cranked it until it pinged then took a fuzz out and locked it down. Most people who rode in it thought it was a small V-8 by how it ran. Nope, I6 Power!!
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE. |
02-06-2009, 10:37 AM | #28 | |
Active Member
One question: I'm confused on the "one light spring and one medium spring" thing. Can you explain? |
02-06-2009, 12:48 PM | #29 | |
Champagne Taste on Beer Budget
That kit sounds like a good idea if it helps on fine tuning.
Coming Soon: Project 1970 Country Truck |
02-06-2009, 02:04 PM | #30 |
72 GMC
02-07-2009, 12:15 AM | #31 | ||
I had a V-8
Now, speaking of advance, the vacuum advance unit is set for a specific amount of advance. There are many different units available that have different total advance, so this is another avenue for more precise tuning of total advance. Once upon a time, some company made an adjustable vacuum advance unit that could be adjusted with a tiny allen wrench to set it to whatever total advance was desired. I never used one, nor do I know if they are still available, but it might be another option depending how carried away you want to get. Well, I guess instead of telling you what time it is, I ended up telling you how to build a clock, but now you know. Oh, one more thing--on my 250 with the HEI, it really like manifold vacuum to the vac advance while the points dist liked ported vac. If you decide to try manifold vacuum, you will need to adjust the idle speed on the carburetor down a bit because it will be at full advance at idle. The advance will drop under power (as it should) and come back in cruise conditions (High manifold vacuum). I don't know why it liked it so much, but it definitely ran better set up with manifold vac as compared to ported vac. Ok, I'm done--I swear. Hope it helps!!
