Old 03-06-2003, 12:39 AM   #1
XXL
Seņor Member
XXL's Avatar
Dropped trucks and the "front fender issue"
For those of you with bagged trucks, you are probably aware of the front fender clearance problem (where it hits the tires when dumped)...
I did some staring at my truck earlier this evening and it seems like you might be able to clearance the arc in the fender sheetmetal by 2+ inches. Notice that there's a small hole in the hood hinge bracket just forward of the rear mounting bolt. Maybe you could drill that out to the appropriate size, properly gusset it on the rear, and use that as another mounting hole for the hinge. Then remove the bottom mounting bolt altogether. That would let you trim up the sheetmetal to at least the bottom edge of the hinge, and possibly up into the hinge 1/2" or so without impacting functionality of the mechanism or weakening it. Then you could roll a new lip into the bottom of the fender cutout area and gain some more room. Does this make sense? Or should I go to bed and get some sleep??
Kenneth
XXL is offline   Reply With Quote
Old 03-06-2003, 11:09 AM   #2
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
I already trimmed my fenders up to the hinge. I thought about the same thing on the hinge to get an extra inch. I have no tire hitting. My tires are 27" tall and I currently have about 1.25" of clearance. I can roll full down I just have no turning radius.
Thinking of shorting the lower and upper control arm by an 1" for turning. I seen it in Streetrucks, the guys at IF did it on the BURB.
My only concern with the hinges is when you get into a Body drop, with just the normal setup like mine and yours it doesn't seem to be a problem.
01 Tahoe 22's 2/4 drop and tv's
68 chevy money pit
51 chevy belair
95 Honda 900RR
05 GMC Siearra (company truck)
NSANE68!!! is offline   Reply With Quote
Old 03-06-2003, 11:27 AM   #3
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
When you cut the frame for a body drop, do you also Z the front
for the core support so all the sheet metal lines up? and what clearance problems does that create ? radiator,air cleaner.
You never see pics of the front, allways of the rear?
sneakysnake is offline   Reply With Quote
Old 03-06-2003, 03:05 PM   #4
SCOTI
SCOTI's Avatar
XXL, I've got a set of wheelwells cut up trying to resolve this. I'm trying to remove a 2-3" horizontal section out of the center of the inner fender structure, then raise the top of the wheel tub, but leaving it bolted up just like stock. This will require some trimming of the hinge itself. I'll keep the bottom of the wheel tub bolted in it's stock location as well & try & piece the rest back together w/spare, cut-up, wheel tub pieces. My lower a-arms are already narrowed about 3/4" each side so the uppers don't require as much shimming to align.
My buddies are trying to get me to just build some new ones from scratch w/a different hood hinge assembly, but I don't think 'new' ones would blend w/my traditional look under the hood as well as modified stockers.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-06-2003, 03:22 PM   #5
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
Someone on the board is using mid 80's dodge truck hinges that mount to the firewall. That would make clearencing the inner fenders easy. Wouldn't it?
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
Old 03-06-2003, 06:03 PM   #6
SCOTI
SCOTI's Avatar
That may work but I spent a bunch of time smoothing all my firewall so I'm not sure how some hinge plates bolted on would look. I think it was lotiks truck that had the Dodge hinges but I haven't seen pics up close enough to decide one way or the other.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-06-2003, 06:52 PM   #7
RACING29
CAn you run 20"s with bags? Will they hit the hinges? THANKS
1967 Chevy truck, R1 racing seats, 4 point racing harness, 4/6 drop, primered blue, soon to be shaved, 350- 060. over, flat top pistons, Eagle rods, Edelbrock Aluminum heads, 1.5 Scorpion roller rockers, Lunati 515" cam, mallory ignition, Holley 750 double pumper carb, Built 350 turbo trans, 2500-2800 boss hog stall, 20 gallon aluminum fuel cell!!!
RACING29 is offline   Reply With Quote
Old 03-06-2003, 08:02 PM   #8
SCOTI
SCOTI's Avatar
It just depends on how low you go & the final tire height.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-06-2003, 08:40 PM   #9
XXL
Seņor Member
XXL's Avatar
Originally posted by sneakysnake
69 cab 41/2" chop
67 frontclip(tilt) swb step(tilt)
71 ps db 5 lug
83 350 4bolt th-400
72 tilt,a/c,pl,pw, shortbkblz seats w/consol shavedhandles,frenched ant (gasneck)
78 camaro shark gills
78 monte carlo head lights
68 impala rear bumper
It sounds like you need to post some pics of this thing! I'd especially like to see the cab chop and tilt.
Kenneth
Old 03-06-2003, 08:57 PM   #10
crazy longhorn
Fabricate till you "puke"
Chops & tilts go together!.....here you go XXL http://community.webshots.com/user/hotrodhorn
crazy longhorn is offline   Reply With Quote
Old 03-06-2003, 09:15 PM   #11
>X<
registered IWATA user
>X<'s Avatar
sneakysnake, please post some pics!
-'63 Ford Fairlane 500 coupe, v8, auto, faded and rusty. awaiting built roller 302 and some flat black
-'99 Honda Prelude. vtech/5spd. no pipe, no intake, bone stock. awaiting new top end.
-01 GMC Yukon SLT 5.3 dented and scratched with a noisy tranny.
Take off that Von Dutch hat before i stab you with a 000 Mack.
>X< is offline   Reply With Quote
Old 03-06-2003, 09:20 PM   #12
lotik
drag it like you stole it
i have a couple answers. get a tilt front end/hood, or get some different hinges like i did. mine are from a dodge. they make some billet ones. they just need to be firewall mounted.
negative camber //LA\\
lotik is offline   Reply With Quote
Old 03-06-2003, 09:23 PM   #13
XXL
Seņor Member
XXL's Avatar
Man, I've looked at your pics so many times, they're burned into my monitor!
Kenneth
Old 03-06-2003, 09:37 PM   #14
crazy longhorn
LMAO! XXL, I have burn marks in my soul from that old truck!(a few on me skin too) crazyL
Old 03-06-2003, 09:47 PM   #15
SCOTI
SCOTI's Avatar
Lotik, could you see if you've got any close-up shots of those hood hinges + how they're mounted & post them if possible. Thanks, Scot
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-07-2003, 12:14 AM   #16
RACING29
I talked to TURNER ENTERPRISES today and he said he had a kit to get my truck to lay the pinch weld?!?! I'm going to talk to him more tommorow.
Old 03-07-2003, 12:02 PM   #17
sneakysnake
seanh71, at the moment i dont have a digital camera, but sense I
have found this board it has created a real bad itch to uncover my truck blow the dust off . marriage,kids, divorces take there toll
on a project., but i have a new found enthusiasim, Ill try to beg,borrow or buy a camera and post some pics so keep a look out.
Old 03-07-2003, 04:59 PM   #18
>X<
>X<'s Avatar
hey man, if you buy one look in to the Intel cheapo, it came with my comp but thy are only like 90 bucks, and store like 200 pics, the stuff you take pics of has to be still though
