02-09-2009, 10:36 AM | #1 |
hood stiffening pads?
Does anyone know where I can get hood stiffening pads for a 67 gmc hood?
tHANKS |
02-09-2009, 10:43 AM | #2 |
accepting donations
Re: hood stiffening pads?
I've seen people spray that expandable foam between the hood and hood supports.
1999 Yamaha roadstar 1600 chop. (in progress.) See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/ "Ya'll can go to hell, I'm going to Texas." David Crockett |
02-09-2009, 11:00 AM | #3 |
Just about all our vendors carry them. I got some from Classic Industries, but try Brother's or GMC Pauls. Lots of sources.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
02-09-2009, 11:10 AM | #4 |
THANSKS A LOT, I'll call one of them
02-09-2009, 12:13 PM | #5 |
From personal experience - DO NOT use the expanding foam on the bottom of the hood...
I have that on my Blazer right now - looks like crap and it difficult to get off. |
02-09-2009, 08:13 PM | #6 |
Also try LMC Truck
02-09-2009, 10:35 PM | #7 |
got a set ordered today, 14.00 thanks guys for the help
02-09-2009, 10:52 PM | #8 |
Active Member
Word of caution. Be extremely careful when prying between the hood and the metal brace to slip the pad in. The top of the hood can be easily bent. Also, unless you need them, don't replace the ones in the very front of the hood. That's harder to pry apart.
I used a wide wooden wedge shaped piece to slowly and carefuly tap and pry the area just wide enough to slip the pad in -the second time I did it. |
02-10-2009, 09:53 AM | #9 |
Thanks 68gmcsee, sounds like good advice
02-10-2009, 09:59 AM | #10 |
My pads are to thin. I have new ones, but the space is to wide for my new pads. Is it ok to glue them?
02-10-2009, 10:30 AM | #11 | |
Active Member
The idea is to keep the hood from rattling and to stiffen it so it doesn't vibrate up and down as you drive on the roads. I'd try to locate some thicker pads or padding. But to answer your question, I don't think it would hurt to silicone them in place. It would just make it harder to replace in 20 to 30 years. |
