Old 02-09-2009, 10:14 PM   #1
maxreps
Possible to use front coil springs from a 71 on a 76?
both 1/2 ton 2wd's..
maxreps is offline   Reply With Quote
Old 02-09-2009, 10:16 PM   #2
71swb4x4
71swb4x4's Avatar
Re: Possible to use front coil springs from a 71 on a 76?
I am almost positive they will.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 02-10-2009, 10:39 AM   #3
maxreps
FYI.. if anyone ever needs to know.
I got lucky and found out that '72- are shorter by about 2.75" and have a spring rate that's about 150lbs/inch less. So stock springs for a '72- would lower a '73+ about 2.75". But they're also about .75" smaller overall diameter with a pigtail end whereas the '73+ springs aren't.
