Old 03-07-2003, 06:57 PM   #1
iluvmy72
Lightbulb can 72 body fit on 95 SWB frame?
I had a wreck the other day....need a new grill and bumber......but I bent the frame in the front......however I just found out today I can get a rolling chassis from a 95 SWB.....how many mods would I have to do to get this to work?
iluvmy72 is offline   Reply With Quote
Old 03-07-2003, 10:08 PM   #2
ChopTop
You will have your hands full with the modifications. I've never done it myself. I would'nt recommend that frame. Honestly I don't see much to gain. It has the same technology in the front end as a 71 for the most part. You would be giving up your current 12 bolt, which is pretty stout. I have driven many of those newer trucks and have noticed in reverse they flex and hop.
Member of the "Old Farts Club"
ChopTop is offline   Reply With Quote
Old 03-07-2003, 11:06 PM   #3
Blue_71
Bloo
Blue_71's Avatar
never noticed the flexing, but my dads 89 4x4 does hop bad in reverse, especially in loose dirt
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 03-07-2003, 11:09 PM   #4
67cst
i love summertime
67cst's Avatar
if it is all like the 73-87 frames dont, it wont work unless its a 4x4, we tried a 85 swb frame under a 67 short step...the frame bends up too early on the way to the rearend, so the rear cab mounts are too high, causing the body lines on the cab and box not to line up, if it is a 4x4 though it should work fine because the body can all be lifted maybe 2-3" off the mounts
Derek
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
