02-10-2009, 06:27 PM | #1 |
Burnouts are therapeutic
what is this?
this was on the 72 mounted on pass. fender next to ths batt. ,I'm thinking maybe for rad. overflow but I don't recall ever seeing one on one of these trucks.but theres a large outlet below the rad. cap. (3/4 I think)anyone know what that is without a pic? also is this of any value to anyone?
1969 CHEVELLE SS 1972 C10 ALMOST DAILY DRIVER 1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE) 1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR) "My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield "The difference between genius and stupidity is that genius has its limits." - Einstein |
02-10-2009, 06:48 PM | #2 |
Moderator
Re: what is this?
I think it is for the charcoal canister (EEC smog stuff)
02-10-2009, 06:49 PM | #3 |
Moderator
Re: what is this?
The large outlet below your rad cap is the heat exchanger for the auto transmission lines
02-10-2009, 06:56 PM | #4 |
Re: what is this?
there is also an over flow tube that comes out fo rad and just drops ontpo the ground
02-10-2009, 07:47 PM | #5 |
Resident of Here
Re: what is this?
That explains why my grass keep dying!
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
02-10-2009, 07:53 PM | #6 |
Re: what is this?
That is the bracket for the charcoal canister- early emissions piece. If you have a large nipple coming from the rad. it is prob a four core rd with a/c . The nipple is for a heater hose return instead of recirculating through the water pump. The over flow is connected to the rad neck and as stated run straight out onto the ground. The overflow reservoirs were relegated to military ,special service vehicles or dealer installed applications.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
02-10-2009, 08:05 PM | #7 |
Moderator
Re: what is this?
Oops, also forgot to mention the one for the heater hose return line. That is more than likely the one you are referring too, as you state it is a large opening.
02-10-2009, 09:45 PM | #8 |
Re: what is this?
okay so this is why they had heater hose connected there and intake outlet blocked and it is a 4 row,so can you just plug the outlet up?also is the bracket any good to anyone?
