Moderator
![]() Join Date: May 2007
hubcap question
How can you tell the difference between 1/2 ton hubcaps and 3/4 ton hubcaps? I see a lot of them for sale on Ebay. Thanks.
Re: hubcap question
Scott,
The 1/2 ton diameter is right at 10 1/2 and has a concave center shape where the bowtie is. The 3/4 ton caps have a 12 inch diameter and have a convex center to clear the end of the differential. Here is a pic that was posted some time back of the 3/4 ton. I did just measure one of my 1/2 ton caps but don't have a picture. Hope this helps. Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
Moderator
Re: hubcap question
Jeff- Thanks for the info. The diameter measurement is most helpful, and sounds like a sure-fire way to tell. I have seen hubcaps with the center pushed in (concave) and pushed out (convex) I thought that was a variation based on the years the hubcap was used on. Pickmup did a post a while back that showed the 73-up 3/4 caps were concave (pushed in) and he just pushed them out to make them look correct for 67-72. I did not think that it made a difference in clearing the diff. Your info is most appreciated!
