03-07-2003, 11:59 PM | #1 |
Project 7dos
OT speaker to amp connection
What kind of wire do i need to hook up 2 10" subs to a 120x2 Fosgate amp?? 12 volt? 10? 8? or is it something special
Thanks Jason
7DOS - 1972 C-10 350/350 Porterbuilt/Accuair 20x8.5/20x10 Ride Low or Die PSSST - Yes it's bagged. 7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290 |
03-08-2003, 12:01 AM | #2 |
My other Love
12 guage speaker wire should be adequate
Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
03-08-2003, 12:01 AM | #3 |
senior member
I would highly recomend going down to your local stereo shop and getting an amp wiring kit also I would use 8 guage wire but the kits come woth the ground remote fuses battery to amp wire everything u need
69 GMC bagged |
03-08-2003, 12:50 AM | #4 |
Captain CAAAVVVMMMAAANNN!
10 ga is pushing it, but will work, but 8 would be better, if you can get some wire that has a high strand count, that will be best. as for speaker wire, 14ga should work fine, just make sure the power wire is fused at the battery, and the ground wire is under 18 in in length, the shorter the better.
72 LWB Fleetside C10 Custom 350/350 97 GMC Yukon 4X4 SLT Anna, Texas check out the project old yeller |
