Old 02-11-2009, 11:28 AM   #26
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Re: Replace studs?
Look to the right of my Hobart.
Disc and hub are held together by studs.
Excuse my mess!
Joey~AP is offline   Reply With Quote
Old 02-11-2009, 11:42 AM   #27
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: Replace studs?
Thanks! You guys really helped!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 02-11-2009, 01:45 PM   #28
Re: Replace studs?
The hub isn`t always seperate from the disc.The unit is known as a rotor or disc.The studs are "pressed" not packed.With owning a 4wd you`ll get to where taking that hub apart is like putting a battery in.
Old 02-11-2009, 01:49 PM   #29
Re: Front hub help!
I hate when you can`t quite get it back in the groove when you`re almost done.Whaaa!!!
Old 02-11-2009, 01:50 PM   #30
thirdstreettito
Resident of Here
Re: Replace studs?
I say packed, I say pressed, it all depends on how I feel...
It's as hard as putting a battery in? GAWD! I'll never get it apart!
~Bradley~
Miss having a truck
Old 02-11-2009, 06:19 PM   #31
Re: Replace studs?
Oh ok.I always feel like saying pressed.
Old 02-11-2009, 07:51 PM   #32
skchevota
skchevota's Avatar
Re: Replace studs?
If you havent pulled one apart before, you will need the 4 prong hub socket to get the nuts off. also be carfull when putting it back together. the inner nut has a small nub stiking out that lines up with one of the holes in the washer between the nuts. You must line that back up when putting it back together. If it wont line up then flip the washer over and try again, if that doesnt work the tighten the inner nut a bit more and repete. If done correctly the nuts wont back off. Ive fount that snap ring pliers work very well to put in the washer.
Remember to repack you wheel bearings while it is apart!
skchevota is offline   Reply With Quote
Old 02-13-2009, 12:34 AM   #33
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Re: Front hub help!
You get it off yet?
Old 02-13-2009, 12:05 PM   #34
Re: Replace studs?
How zit goin?
Old 02-13-2009, 01:17 PM   #35
thirdstreettito
Resident of Here
Re: Replace studs?
I've had strep real bad since Sunday. I am so tired of being cooped up in the house all day, I was so tempted yesterday to start working but I cant! I should be well enough Saturday or Sunday to work on it, I'll tell you guys how it goes. I just have to see if we have snap ring pliers or if I have to go buy some.
~Bradley~
Miss having a truck
Old 02-13-2009, 01:18 PM   #36
thirdstreettito
Resident of Here
Re: Front hub help!
Check the stud thread.
~Bradley~
Miss having a truck
Old 02-13-2009, 04:58 PM   #37
Re: Replace studs?
You can get by with two thin objects like a pen screwdriver or pointer/center punch.
Old 02-13-2009, 05:58 PM   #38
LONGHAIR
Re: Front hub help!
No reason for two threads to do the same thing.....merged.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 02-13-2009, 06:40 PM   #39
thirdstreettito
Resident of Here
Re: Replace studs?
When I was messing with it the other day I was able to push in hard with the pen driver and pry the ring up a bit, but the other pen driver couldn't get under it. Anyone have pics of where to get it under or any pics to help?
~Bradley~
Miss having a truck
