#26 |
Re: What did you get done? 02/08
Got all the leaves out of the yard for mulch for the gardens. About 18 loads in my longbed.
#27 |
Drywall in the daughter's bedroom. Yech. Broke out part of the crack in my basement preparing for the urtethane foam and mortar. Pikced up an 89 Blazer GMC grill from CLfor $50 with NO broken tabs! Started the roof sheathing on my new 9x14 parts shed (I know it's not big enough but the old one fell in....). TOnight, more sheathing followed by more drywall. Then it should be ready for paint.
1987 2 ton ![]() 1982 ![]() Dad's 1981 ![]() Plus a mess o' tractors |
#28 |
dropped off and picked up my cab from body shop. had the drip rail removed and welded up. also had the guy do the finish work with some body filler to make it nice and smooth. I wanted to do this myself, but I didn't want to screw up on the roof of the cab. that is just a little too advanced for me. It's a subtle difference but when you see it next to another truck that subltle difference is a lot. and you dont ever have to worry about the seam sealer in the drip rail rotting out and rusting up the cab. I also picked up my frame from the powder coater. I'm not sure what color I am spraying the truck so I just had the frame coated gloss black. I have had my truck in pieces for about a year now and I am just now starting to make some forward progress. I have been finishing up my shop and now that the frame is done and I have some body work done to the cab, I am committed and can't wait to get the rest of my suspension done so I can start putting some of this stuff back together. Next is finishing off the suspension and replacing my rockers.
#29 |
My truck is an alcoholic
Built a 2" valved reflux still, got some parts for a second, and picked up some of the processing equipment I will need to turn weeds and spoiled fruits/vegetables into fuel for my daily driver, trucks, and drag car. The 454 is going to be swilling straight ethanol this summer after a cam change, an intake swap, and rebuilding the Qjet. With luck the 76 will pull the drag car to the track again after a ten year hiatus from the racing scene. The luck is needed to get the drag car updated for the lower ET it runs now. I doubt anyone here would be interested in ten cent to a dollar per gallon fuel, so I wont bore you with the details.
#30 |
Resident of Here
I painted my grille bowtie red. Looks real good.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
#31 |
I'm just glad to be here!
Spent Saturday working on the house, laid granite tile around the fireplace. Now I have to grout it and the tile for the back splash in the kitchen. Trying to finish up my honey do list so that I can work on my truck...And I got to watch ALL of the Bud Shoot Out that night....
Sunday, took my boys to the race track. We race go karts on a 1/5 mile dirt oval. First race back after a nearly 2 year layoff. New class for both boys. the older on raced this time, came in 2nd in the feature after not doing well in both heat races (mostly my fault, I had the kart to tight, work not turn in the corners, Got it right on for the Feature ![]()
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square Last edited by aggie91; 02-10-2009 at 02:23 PM. |
#32 |
truck addict
i put a 2 inch lift and some 31s on my 00 jimmy.. got the front valance put on.. worked on a few cars... re did the system in my jimmy on sunday.. had a few friends over... still waiting on more parts to complete my jimmy and then i can get back to the c10... i think it really makes this truck stand out.. got black taillights, a tuned ecu, and a few other parts n there way...hopefully they get here before saterday... gotta go watch some monster jam....
trucks |
#33 | |
Mudslides 'r my specialty
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.) http://www.cardomain.com/memberpage/500339 |
#34 |
worked on a tile shower for a buddy, he gave me a brand new set of 22s with tires for the burb so I built him a real nice shower.
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
#35 | |
Son of a .......!!! That is an awesome yet simple solution! Thank you for mentioning that, I should've thought of that before now though. |
#36 |
well i got out of work a 1pm on saturday and called my mechanic. he told me my truck still was not done despite him saying it would be done friday, the day before. after a few hours i just drove down to the shop and saw my truck on the lift with tranny fluid gushing out around the tranny pan. they ordered a new gasket and after 1.5hrs the parts guy drove up, delivered the gasket and left. the mechanic pulled the gasket out and it did not work. he hopped in his car and came back 30mins. later with the proper gasket. installed that and then worked about 45 mins. getting the shift bracket on the steering colum hooked to the gear change linkage. finally hours later at 6:20pm I left the shop $620 poorer with the following done to my truck. new tranny installed(i provided tranny), new tranny gasket and fluid, oil change, exhaust welding, one new muffler, new kick down control, and new flywheel. i was a little mad when i first pulled out of the parking lot and could not step on the gas because the old tranny was floating around in the bed and i did not bring rope or tiedowns to secure the thing. at least now my truck will moved under its own power, now.
#37 |
I picked up my Trailblazer Friday night from a long week without it. I was having some warranty work done to it. I spent early Saturday morning working on a few cars. Later that afternoon my family and I worked in our yard cleaning up leaves and clearing out some trees. Sunday afternoon was much of the same. I took my daughter out for a ride on the atv later that afternoon. Enjoyed the 70 degree weather.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
#38 |
Thanks 8t5Silverado !
I got the car and truck all cleaned up today. Hauling leaves is the one time I cuss the trim on the truck. it holds everything! took forever to get it all out. ![]() |
#39 |
Resident of Here
Got a pic of the bowtie! There is a red SUV parked in front of it and it looks like overspray!
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() Last edited by thirdstreettito; 02-11-2009 at 02:02 PM. |
