Old 02-11-2009, 07:49 PM   #1
Tantrix
Pics as promised: 1976 C10 long bed
Here's some pics I snapped today. It's not the most beautiful thing, but it's mine.
4.1L 250:
Front passenger side:
Front driver side:
Rear end:
Inside bed:
Interior:
Tantrix is offline   Reply With Quote
Old 02-11-2009, 08:07 PM   #2
Scootin 81 C20
3/4 Ton Rodder
Scootin 81 C20's Avatar
Re: Pics as promised: 1976 C10 long bed
Looks like a good project truck. I love the old school "Land Mine Proof" All Terrain tires. BTW, front-passenger side, I spy a Dodge hubcap.
1981 Chevy Scottsdale C20 "Orange Crush": SOLD
1989 Chevy Silverado K2500: All Stock (For Now), 350 TBI/700R4. DD/Light Duty Toy.
Scootin 81 C20 is offline   Reply With Quote
Old 02-11-2009, 08:11 PM   #3
Tantrix
Yeah, don't ask me why mudders are on the front...it was that way when I got it. I plan on swapping them to the back if I end up keeping them.
Ha! I never noticed that but it sure is a Dodge hubcap on the passenger side.
Old 02-11-2009, 08:33 PM   #4
Scootin 81 C20
3/4 Ton Rodder
I wouldn't have a clue why either. Would you be able to pop that Dodge cap off and measure the distance across if your truck has 16.5 wheels? I'm trying to find a set of Dodge ones so my original Chevy ones don't get destroyed.
Benjamin.
Old 02-11-2009, 08:56 PM   #5
Tantrix
Sure, I'll measure it. Not sure on the wheel size but I'll check.
Old 02-12-2009, 12:58 AM   #6
Square84
I don't think these pills work
Square84's Avatar
looks like a straight truck, very nice. what part of louisiana you from?
SQUARE84
90 SUBURBAN
Square84 is offline   Reply With Quote
Old 02-12-2009, 01:10 AM   #7
Tantrix
I'm of Acadian descent originally from Erath, but I now live in Pineville (Central LA).
Old 02-12-2009, 02:32 AM   #8
gearbuster
You know every truck has to have a little good to it thats why they put dodge hubcaps on it...
lol just playin with you man
gearbuster is offline   Reply With Quote
Old 02-12-2009, 05:48 PM   #9
67-72crazy
67-72crazy's Avatar
nice truck i would drive it proudly the way it is.
1991 1500 longbed: my daily driver
1937 chevy 2dr sedan. dads project
67-72crazy is offline   Reply With Quote
Old 02-13-2009, 01:44 AM   #10
Tantrix
Update:
Well...the new Spectra 20gal fuel tank and Spectra sending unit came in today. I installed it and dumped 6 gals of gas in and when I turned the ignition on my fuel gauge shot up to 1/4 tank...so my sending unit is good (woo woo!)
I dumped a bit of gas into the carb (hadn't been cranked in a while, and no fuel in truck at all) and she fired up and purred like a kitten.
Then, as I go to back it off the ramps...rookie mistake kicks in:
My shift pattern was wrong...I had the plates that screw into the transmission to change gears hanging down instead of sticking up so my gears were backwards. After flipping those upwards and tuning my linkage for short-throw shifting, everything was done.
I aired up the tires and headed up the road to the military rifle range/WMA gravel roads and test drive her. Shifting was smooth, and everything worked (heater, lights low & high beam, etc)
Problem still keeping the truck from being road-ready:
However, even with both feet on the pedal pressing as hard as I could, I locked up the brakes and the truck pulled hard to the left and turned a complete 90 degrees pointed toward the left ditch of the gravel road...a clear indicator I'm still not getting brake fluid to my front passenger wheel disc brake.
I disconnected the metal line from the proportioning valve and brake fluid came out there, so I have a clog somewhere in my line(s) going to that one front passenger wheel.
I guess I'm going to heat to NAPA tomorrow and get a length of metal brake line, a tube bender, a flare tool, all my fittings, and a new rubber line to go to the caliper. That should take care of it (I hope).
For anyone who's bent their own brake lines and installed them in the front before, I'm open to any advice. I've replaced metal brake lines that were bought already pre-bent but this will be my first attempt at bending & flaring them myself.
Thanks, I'll keep everyone posted on the progress.
Old 02-13-2009, 02:15 AM   #11
Pyrotechnic
Pyrotechnic's Avatar
Nice truck ! What transmission is that ? Looks to be of the car variety. Just so used to seeing the SM465 in V8 trucks.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 02-13-2009, 03:52 AM   #12
Tantrix
It's the 3-speed on the column, but my column was busted up so I put in a Mr. Gasket 3-speed floor shifter.
