![]() Join Date: Apr 2001
BB 74 Quadrajet... anything special???
Just pulled this out and rebuilt it, I knew it was for a 74 but just decoded it in my 74 service manual and looks like it is the only carb used for the 454 in the 1/2 ton trucks... Is this worth just using, or is there a market for the carb to one of us, and if so... being freshly rebuilt AND blueprinted as close as I could get to factory specs, anything special????Thanks guys...
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
Re: BB 74 Quadrajet... anything special???
oh and the number is 7044223....pic ain't that great i see...
I believe the body for all the 1980 quadrajet and before are the same, but the jets and metering rods are different specifications, depending on the motor and weight of the vehicle. But car ones have smaller primary bores.
Unless your carb is damaged, your existing rebuilt carb is the definition of factory specifications, that is if it is adjusted properly. It's a balance of economy and power and reliability. It can be tuned to get more power and/or mileage by experimenting with jets and metering rods.
79 Blazer Cheyenne, 2wd 305 3.42 stock 85 Caprice, TBI converted, new 350 crate motor, Monte Carlo SS Wheels, Bilstein shocks, |
Oh whoops, I didn't realize it isn't matching your truck. If you put that on a SBC it may be off or close if the motor is hopped up. I believe you could swap jets, and metering rods to suit the specifications of the motor you use.
oh.. im not worried about tuning it... these things have kind of become a recent passion of mine... I just didnt know if, like some of the musclecar carbs in the day, they are anything special. Like "don't use that one, build a different one cuz someone needs that carb for their resto!"... I dont believe its an 800cfm either, BUT I will say that I would have to change at least the primary enrichment system to get it to run lean enough for a stock or slightly modified small block... thanks for the input...
--Mike
