Old 02-13-2009, 11:38 AM   #1
Loki
Loki's Avatar
Finally out of the shadows
I've been lurking in the corners around here for about a year reading and learning. I'm a Wyotech grad, former Subaru Tech and Chevy Installer (almost 10yrs ago).. anyway.. I picked-up my first truck about a year ago, a '67 short step. base model small back window, no a/c, 250cid 3 on the tree. Worked solid for about 2months and picked up an 86 monte carlo SS that ran, so the truck went to the back burner for a bit. just picked up an 86 1/2 ton long bed donor truck so it's time to revive the 67...
Sorry for that I know it belongs in the Newbie section.
On to the Question. Ive been looking around and have found posts on swapping the mounts from the 86 to the 67, and i know i will have to grind out section of the frame to fit the steering box. (no notch in my frame) since im going from 3spd to TH350 is my low floor plan going to be an issue? i think i should have more than enough room at the fire wall for the engine..
will also be selling off the body and remains of the 86 when finished. Ill post pics in the Sales section when I have them w/ in the next 2mo..
also looking for any pics i found 100's of chevy and i know mines the "ugly" step-brother but who wants to fit in??
Loki is offline   Reply With Quote
Old 02-13-2009, 12:29 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Finally out of the shadows
Welcome, to the site. Glad you're out of the shadows and into the the light.
I converted my 69 250 three speed manual to 350/350 with no space problems. Frame, cab, dimensions on these trucks are pretty much the same.
Here's a pic of my unfinished, continous work in progress, 68 GMC.
68gmsee is offline   Reply With Quote
Old 02-13-2009, 12:40 PM   #3
my67chevytruck
Under Construction
my67chevytruck's Avatar
welcome, post up some pics!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 02-13-2009, 12:52 PM   #4
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Welcome to the site! Let me be the first to say:
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 02-13-2009, 01:03 PM   #5
bigguy69
dazed and confused
bigguy69's Avatar
welcome!! lets see some pics!
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 02-13-2009, 01:19 PM   #6
sswitzke
sswitzke's Avatar
from SW MO.
sswitzke is offline   Reply With Quote
Old 02-13-2009, 05:07 PM   #7
Loki
Loki's Avatar
Here's a few from when i purchased... and state when i stopped about 6mo ago.. will get more as i go over the next few weeks
Old 02-13-2009, 05:28 PM   #8
Loki
Loki's Avatar
Here is a few, of the parts i have done along with the hood..
seem to be missing the pic of the individual parts pics.
Old 02-13-2009, 05:38 PM   #9
Loki
Loki's Avatar
and just for kicks... Here's the Mighty Monte.. AKA.. The Metal Slug.. (is currently having carb. and suspension issues)
Old 02-13-2009, 05:55 PM   #10
67_C-30
I have a radical idea!
67_C-30's Avatar
Welcome to the board. Great looking project. Everybody knows 67's are the coolest, but some only admit it to themselves! Just an FYI if you don't already know, you can use the front disc brake stuff off the '86 on your '67 if want discs. Saves lots of $$$ doing it that way.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 02-13-2009, 05:57 PM   #11
michael bustamante
michael bustamante's Avatar
nice monte! I used to drive a regal t type and would race these all the time. looks like the tires are rolling a little off kilter there
great lookin 67 GMC there too, I like them early 4 eyed trucks
1967custom
michael bustamante is offline   Reply With Quote
Old 02-13-2009, 06:31 PM   #12
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the tires are just too small for the rims from what i see.
Don't let the chevy guys give you and grief.... GMC's are cooler, everyone knows it, yet only few admit to it.
Your low hump cab is going to be fine. That's what GM put over small block/auto equipped trucks, all 3 auto trannys... dfon't let anyone tell you otherwise. There were a few odd balls that had an unexplainable high hump with that combo, but they were built 'wrong'.
Let me be the first to say... I hope you keep the stepside bed on there. Short step trucks are sexy, a 67 GMC one is even better.
I agree on the disks off the parts truck, and if your GMC has the leaf sprung rear (most GMCs did) then you can just swap your later model rear in there too. 5 lug and disk brakes.
Old 02-13-2009, 07:43 PM   #13
Loki
Loki's Avatar
Thats the only reason i bought the 86.. Brakes, power steering, a/c components (mostly cores)
Old 02-13-2009, 07:46 PM   #14
Loki
Loki's Avatar
the brakes are the main reason i picked up the 86.. couldnt say no to a complete truck for $300.. And yes the guy i bought the Monte Carlo from has 15x8.5... im looking for some factory replacements..
Old 02-13-2009, 08:15 PM   #15
LockDoc
The Older Generation
LockDoc's Avatar
I'm not sure if you are aware of this but you will have to be a "subscribing member" to post for sale items. It is $25 per year and helps keep the board chugging along.
LockDoc
Leon
Old 02-13-2009, 08:20 PM   #16
jbristo67
resident oilfield trash
jbristo67's Avatar
you have to shave that side marker light. You have a 67 you know
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 02-13-2009, 08:25 PM   #17
jbristo67
jbristo67's Avatar
Does that truck have leefs in the back or coil springs
2011 Nissan Armada
Old 02-13-2009, 08:32 PM   #18
Loki
Loki's Avatar
The truck in running leaf in the rear, so does my donor truck... the fenders are repro. and have some major fit issues on the driver side. am going to use them to repair the originals on both sides..
Old 02-14-2009, 12:25 AM   #19
67_C-30
67_C-30's Avatar
Says the man who put a '67 - 68 grill in his burb instead of a 4-eyed face!
My trucks
Old 02-14-2009, 01:09 PM   #20
R.L.
R.L.'s Avatar
Welcome to the fourms, looks like you have good taste in vehicles; love the SS.
R.L. is offline   Reply With Quote
Old 02-14-2009, 01:24 PM   #21
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Welcome to the board, and great looking project!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 02-14-2009, 03:28 PM   #22
68shortstep
Looks good at 20-ft .....
68shortstep's Avatar
Glad to see another sidemount-spare stepper.
The early '80's front end & axle swap to get 5-lugs was exactly what was done to mine.
68shortstep is offline   Reply With Quote
Old 02-14-2009, 04:21 PM   #23
Longhorn Man
That's what I had on hand.
But, you are forgetting, the 69/70 GMC front end I installed on my 70 chevy Longhorn.
Old 02-15-2009, 03:30 PM   #24
Loki
Loki's Avatar
Haven't decided if im keeping the side mount spare.. I have mixed feelings about it. not to mention it means spending extra $$ on a 5th rim
Old 02-15-2009, 04:05 PM   #25
Loki
Loki's Avatar
a few extra pics of the major damage areas...
