Old 02-14-2009, 12:13 AM   #1
chevyman8
chevyman8's Avatar
What headers will fit?
What all headers will fit my '84 w/ a 350ci? I'm looking for some under $500. I want the ceramic coating, and 3" collectors. Any help would be greatly appreciated!
chevyman8 is offline   Reply With Quote
Old 02-14-2009, 12:24 AM   #2
f.monroe
f.monroe's Avatar
Re: What headers will fit?
I think if you look on Jegs or Summit Racings website you can find a Heddman Elite series header that will be what you are looking for .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 02-14-2009, 06:49 PM   #3
Mike_D
check ebay, I just found a set of hedman headers with the high temp coating. $260 shipped to my house. will be installing on tuesday
Mike_D is offline   Reply With Quote
Old 02-14-2009, 07:52 PM   #4
pokethesmot
profeshinaly unimployed
pokethesmot's Avatar
make shure you take tons of pics lol
"having mud flaps is like asking for a smaller trophy"
pokethesmot is offline   Reply With Quote
Old 02-14-2009, 08:00 PM   #5
chevyman8
chevyman8's Avatar
My brother has hedman shorties on his '55 belair and says they have a different port shape from other headers so you have to buy their gaskets and they only make paper which blow out easy. Is it true that camaro or nova headers will work?
Old 02-15-2009, 03:02 AM   #6
jared78
jared78's Avatar
you bet chevelle, camaro monte carlo headers will fit. I have coated hedman car headers on mine. If you sit low, they are great for gound clearance. They will also fit 67-72 pickups also. here is a picture, hope it helps!
jared78 is offline   Reply With Quote
Old 02-15-2009, 06:25 AM   #7
fast75
Go Hard or Go Home!
fast75's Avatar
which ever brand you choose, be sure to get them with 3/8 flanges. i have long tube hedmans with 1/4 flanges and blowing header gaskets like a madman. i've tried everything short of changing them out...just my 2 cents.........
75 short wide 350, some mods, scare the piss outta ya quick.
2008 Dodge crew cab. YEAH, it's got a hemi, your ass is going to jail quick.
Some day's, it's just not worth chewing through the restraints................................
fast75 is offline   Reply With Quote
Old 02-15-2009, 10:42 AM   #8
maxreps
So what's the difference with them concerning ground clearance? Do they not come all the way down and turn back like long tubes for other models>
maxreps is offline   Reply With Quote
Old 02-17-2009, 01:24 AM   #9
jared78
jared78's Avatar
you got it. if you look at the picture of mine under the hood, you can see that where the header goes past the frame. well the collector is right there. they basically go back at a 45 degree angle and stop before turning to go under the truck. A good exhaust guy can tuck the head pipes right up against the floor.
Old 02-17-2009, 11:37 PM   #10
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I run 3/4 lengthe Chevelle headers. The work great. The passenger side is a little close to the starter.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 02-24-2009, 10:28 PM   #11
chevyman8
chevyman8's Avatar
Thanks, I appreciate all the help. I would like to tuck them closer to the floor cause I plan on lowering it 3/5. I think I might try chevelle headers.
Old 02-24-2009, 11:35 PM   #12
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
how about some part numbers guys.
staggerd86c-10 is offline   Reply With Quote
Old 02-25-2009, 12:34 AM   #13
jared78
jared78's Avatar
hedman 68606 is what i've got.
Old 02-25-2009, 12:56 AM   #14
staggerd86c-10
thanks. anything off of a chevelle, monte carlo, camaro may work?jegs makes some ceramic coated ones that look pretty good and are only like 220 bucks. what do you guys think?
Old 02-25-2009, 10:23 AM   #15
Storm Chaser
Storm Chaser's Avatar
My buddy just bought some "house brand" headers from either Summit or Jegs (can't remember which). They were full length and were advertised as fitting his truck. The idea was to run header-mount glass packs with turn-downs on the end of the muffler.
Well, the headers did physically fit the truck, but the outlet of the headers aimed the mufflers down at a rearward angle which would have made the glass packs dangle real low to the ground. Whats worse is the passenger side glass pack would have rattled against the tranny crossmember, and the driver side wouldn't go on at all because the header outlet was aimed directly at the crossmember. There was also issues with the Edelbrock intake/carb combo that was advertised as having everything you need, but didn't, but that's a story for another time.
My question is- does anyone make a full length header where the outlet aims the exhaust parallel with the floor, and maybe be up enough that the exhaust would run above the crossmember? My buddy ended up making his own exhaust, but when I do mine, I want to use header mount glass packs with turndowns right before the rear axle- it sounded great that way on my old Nova.
1988 R2500 Crew Cab
Immediate plans- get it running!
Future plans-
Rear disc swap & Hydroboost
Dually conversion with shackle flip-n-switch
4x4 conversion with 52" springs
Maybe some new body panels
Who needs a car when they make crew cab trucks?
Storm Chaser is offline   Reply With Quote
Old 02-25-2009, 11:09 PM   #16
73chevyman
73chevyman's Avatar
due to the cross member they are hard to find unless you modify the cross member but the hedmens work the best
http://67-72chevytrucks.com/vboard/group.php?groupid=37
73 C10 Fleetside
If it ain't a Chevy it's foreign
http://hotridesmag.com/
73chevyman is offline   Reply With Quote
Old 02-27-2009, 10:00 AM   #17
BP68
BP68's Avatar
I started with hight temp coated headdman's (not ceramic) they turned color and dulled while storing them on the motor/frame (out in the moisture). Plus the longtubes hung way low on my 68 2wd.
I switched over to Sanderson Ceramic coated mid lengths from ECE and LOVE them. Fit great and look great. Highly recommended and the were under 500.00
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 02-27-2009, 10:34 AM   #18
Storm Chaser
I don't mind modifying the crossmember, myself (my buddy wasn't into the idea). Do the Hedmans pretty much run parallel with the floor, rather than aiming downward?
1988 R2500 Crew Cab
Future plans-
