03-27-2008, 02:48 AM | #1 |
what rearend do i have
i swapped the rearend n my 68 to a 5x5 pattern.. and it sits on coilsprings ..
i have no idea what year truck the rearend came out of though, any help |
03-27-2008, 03:22 AM | #2 |
Re: what rearend do i have
more info needed. got a pic?
03-27-2008, 03:38 AM | #3 |
there should be some numbers stamped into the axle tube ...think on the passenger side....those would help the gurus figure it out
03-27-2008, 03:54 AM | #4 |
Signals in the bumper.
Perhaps an early 70's Blazer, Chevelle or Nova?
Jeff C. 1981 Chevrolet Silverado - Under major construction...again. link 1962 Chevrolet Impala 4D Sedan moredoorclassics.com 1936 Ford Pickup - Frame-off in progress link 1979 Chevrolet Camper Special Flatbed link |
03-27-2008, 04:44 AM | #5 |
A picture will help to quickly identify it.Impalas and caprices had coils,so did Chevelles and other GM's. Is it a 10 bolt or 12 bolt? Can we see the rear end cover?
Current ridesne owner GMC 1974 swb, 1986 Chevy lwb,chopped top '85 S-10,1948 Stylemaster rat rod,'2008 Honda Civ.Chopped top '46 dodge. |
03-28-2008, 02:53 AM | #6 |
ill try and get some pics friday.. i know it has a 306 gear in it because i pulled the cover and checked it.. and when i bought it the guy told me it came out of a truck?? thats all i know about it.. ill try to get some pics
03-28-2008, 04:02 AM | #7 |
i don't think 3:06 ratio was offered in the trucks ... maybe 3:08?
03-28-2008, 03:45 PM | #8 |
71 and 72 Chevy's with disc brakes are 5 on 5 pattern from the factory. Chevy's had coil spring rear as an option. I've owned a 72 and a 71 that both where coil spring rear and 5 on 5 from the factory.
66 Chevy Stepside tandem project My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902 |
03-31-2008, 03:37 AM | #9 |
well the rearend is not disc brakes.. it drums but im assuming it is out of a 71 or 72
03-31-2008, 03:42 AM | #10 |
04-02-2008, 01:01 AM | #11 |
well th rearend is a 12 bolt, non posi. 306 gear, coilsprings,
and it measure 65 inches from flange to flange.. soes this help at all |
04-02-2008, 04:04 AM | #12 |
I had something to say but re thought.
Current ridesne owner GMC 1974 swb, 1986 Chevy lwb,chopped top '85 S-10,1948 Stylemaster rat rod,'2008 Honda Civ.Chopped top '46 dodge. Last edited by danielwetpaint; 04-02-2008 at 04:23 AM. Reason: 4 beers to many. |
02-09-2009, 11:19 PM | #13 |
any help.. still no answer on what rearend this is... the specs that o know are 2 posts above
My build thread--http://67-72chevytrucks.com/vboard/s...d.php?t=300333 |
02-10-2009, 07:42 AM | #14 |
My point is 71-72 trucks that came with disc brakes on the front from the factory are 5 lug trucks. The earlier trucks with drums up front are 6 lug trucks. Chevy stopped putting coil spring rearends in any truck in 72. Therefore, if your rear axle is a truck axle, 5 lug, and on coil springs it had to have come from a 71 or 72 Chevy that came factory with disc brakes up front.. This is the only trucks that came with this combination from the factory.
02-12-2009, 05:42 PM | #15 |
Champagne Taste on Beer Budget
I am with the other guys here.
There should be a set of numbers on the passenger side axle tube with numbers. Find it! Post it! And lets see if someone here can help ya!
Coming Soon: Project 1970 Country Truck |
02-15-2009, 12:52 AM | #16 | |
Now,... on the top of the passenger side axle tube, there will be some letters and numbers stamped into the housing. If you can get me the 3-lettered code(only 70-72 had 3 letter codes, 69 & earlier had 2 letter codes) (example...THA, TRS, RHB, RRS, etc) from this location, I am holding a piece of paper that tells what that axle originally had in it for gears, depending on code may tell me exactly what year the axle is from... PM me if needed... Anyone else that needs 67-72 axle code referenced, PM me... I have a chart, but 1967 to 1972 only.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 02-15-2009 at 10:46 AM. |
