Old 02-12-2009, 04:54 PM   #326
Richard H.
Spanked once
Richard H.'s Avatar
Re: project INCREDIBLE HULK 6.2L with 6L80E
Originally Posted by 68 short step View Post
sorry, yes it is a VA gen 4 magnum.....i use the VA condensor/ dryer that is SPECIFIC to the 67-72 chevy trucks, and then i make my own A/C and heat lines.....
any more ?s just ask, ill be glad to help if i can...
thanks for the complaments
you will need to fab some kinda mounting bracket, and weld it on.....they make it real easy to adapt their mounting bracket to something you can fab up and weld....its not bad at all.
Sorry I dropped the ball responding to your reply. I called VA about this and he kept asking why I wanted a Gen 4 for a pick up. He was saying it would be great for a burb or van but to much air for a pick up so I went for the Gen 2 which should be quieter. As a side note ,I read somewhere that their brackets could use the original mounting holes so I welded in studs. If not I will just wack em off and go from there.
Thanks again
BTW the Gen 2 is cable less also
The ole 350 budget build.
Richard H. is offline   Reply With Quote
Old 02-12-2009, 05:07 PM   #327
killer71
killer71's Avatar
killer had a gen IV and down in louisiana it worked gr8!
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 02-15-2009, 08:44 PM   #328
68 short step
getting this thread back to the top.....got some new custom made moser axles (they are a great co. to do business with) they are really short and fit awsome.....
also i cut up the new ART arms, so they'ld fit the new V3 DM design...and bolted up the uppers arms too....next week ill get the rack installed and hopefully have the steering linkage hooked up too... here are the pics
68 short step is offline   Reply With Quote
Old 02-15-2009, 09:40 PM   #329
Hart_Rod
Hart_Rod's Avatar
That looks pretty sweet..........
Hart_Rod is offline   Reply With Quote
Old 02-15-2009, 11:10 PM   #330
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Front cross member looks killer..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 02-16-2009, 12:52 AM   #331
nuke1
nuke1's Avatar
looking good, gotta love the look of the short axles just means wide rubber, it also looks tlikethe two of us got some frontt suspension put together, way to go.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 02-16-2009, 09:46 AM   #332
Blitz
Mr. Thread Killer
Looking good. How about a wide angle shot of how far along everything is just to put the project into perspective.
Any updates on the gauges? Interior?
Blitz is offline   Reply With Quote
Old 02-16-2009, 04:43 PM   #333
BigShoe24
True Addiction
BigShoe24's Avatar
Looks GREAT! What are you doing for Brakes?
RCC
BigShoe24 is offline   Reply With Quote
Old 02-16-2009, 10:40 PM   #334
68 short step
will get some up soon.....
BIGGGGGG. thats all i know.....
Old 02-16-2009, 11:32 PM   #335
BigShoe24
True Addiction
BigShoe24's Avatar
68 Short Step,
I was wondering because I have a narrowed 9" moser out back as well. I can't decide what I want to run.
Great Build!!!
RCC
Old 02-22-2009, 10:28 AM   #336
68 short step
got the front of the frame notched for the rack.... the rack fits fine, but the low mount alt. hits the the steering part of the rack...so a adaptor bracket is gonna be made to locate the alt. out and clocked at about 20* so it'll fit without hitting anything.....
Old 02-22-2009, 10:30 AM   #337
68 short step
also if anyone wants to know how these builds go with parts comeing in almost everyday, this is about 2weeks of boxes stacked up, and most of the boxes have boxed inside ......
Old 02-22-2009, 10:46 AM   #338
killer71
killer71's Avatar
Man, looks like it's gonna be a chore routing the steering linkage from the column to the steering box!
R.I.P.
Killer 71
10/26/07
Old 02-22-2009, 03:08 PM   #339
68 short step
its gonna be about a 45* angle from the steering column to the rack, the manufacture says that 65* or less is fine, so we should be fine
Old 02-22-2009, 03:25 PM   #340
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Looking killer. What rack are you using?
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 02-23-2009, 09:57 PM   #341
babyblueoval
babyblueoval's Avatar
This looks about like my corner in my friends shop where all my stuff is, except I have a set of wheels and tires in the stack too.
Jim
'71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E
'57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works
'87 BMW 325i - daily driver
babyblueoval is offline   Reply With Quote
Old 02-24-2009, 02:56 AM   #342
tdave00
Restoring a 68 SWB
tdave00's Avatar
Can you tell me a little about how you did your notch? What size pipe, etc. I bought a bolt on notch but thinking of sending it back and doing this instead. I was thinking of boxing the inner frame for strength. Do you think it needs it?
tdave00 is offline   Reply With Quote
Old 02-24-2009, 10:21 PM   #343
68 short step
sure, i used a 4" ID pipe with a .125" wall....i cut 3" (or the width of the bottom of your frame), at a slight angle (cause these frames do a joggle, where the notch needs to go)....once i had the round peice, i cut it in half so i had two half circles....found the centerline of the half circles, and matched it up to the centerline of the rearend(post 89 kinda shows this)....made a mark around the half circles, cut them out, then weld in the notch...
as for boxing the frame there, it cant hurt.....do i think its strong enough and safe without boxing it, yes......
Old 02-25-2009, 02:00 AM   #344
robmrtnbb5
robmrtnbb5's Avatar
Good lookin build their 68 short step
bondo bob
http://s424.photobucket.com/albums/p...albumview=grid <<<link to my stuff and project 68 step side build
robmrtnbb5 is offline   Reply With Quote
Old 03-14-2009, 10:54 PM   #345
68 short step
ok, i got the new alt bracket fabbed up....it spaces the alt out about 1 5/16" and clocks it 20* to clear the rack......also had to remove the ear off the alt. (since it was clocked)... also got some new sheetmetal hung, the fit on the front fender is good (little hole enlargeing, to get proper gaps), and the door is decent.....it will require a bit more massaging, welding, and cutting (more on this later).....but it cames with the aftermarket panels, i guess.....
also got some bed panels in too....the rear cross sills are polished stainless steal (still have the protective film on in the pics tho) and the bedsides are original ones (from the boys at stoked out in rockwall TX)
the one center cross sill (goes between the tires) is too long ,do to the rear end being narrowed, so it will need to be trimmed.....also the bed wood will need to be raised a bit to clear the rearend houseing, and the tubs widened, but that was planned on anyways.....here are a few pics...
Old 03-14-2009, 10:54 PM   #346
68 short step
Old 03-15-2009, 12:06 AM   #347
HuggerCST
HuggerCST's Avatar
Lookin good!
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 03-15-2009, 01:26 AM   #348
my67chevytruck
Under Construction
my67chevytruck's Avatar
nice work Don!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 03-15-2009, 10:53 AM   #349
FRENCHBLUE72
PROJECT 7DEUCE
B!tchin...
MEMBER #6377
Project "7DEUCE"
Old 03-15-2009, 10:59 AM   #350
killer71
killer71's Avatar
Originally Posted by FRENCHBLUE72 View Post
B!tchin...
I AGREE!!!
R.I.P.
Killer 71
10/26/07
