Old 03-08-2003, 09:01 PM   #1
miket
miket's Avatar
rear end ratio ?
Is there a fairly accurate equation to figure rear end ratio if you know engine RPM and tire diameter?
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 03-08-2003, 09:10 PM   #2
Nova_Cobra64
Nova_Cobra64's Avatar
gear ratio = (rpm x tire diameter) / (mph x 336)
2004 Silverado - Beater
1969 GMC - In progress http://67-72chevytrucks.com/vboard/s...d.php?t=441683
2011 Aveo - Work commuter
2013 Crestliner Fish Hawk 1650 - The reason no work gets done on the project truck.
Nova_Cobra64 is offline   Reply With Quote
Old 03-08-2003, 09:11 PM   #3
jhow66
jhow66's Avatar
With the 350/350 combo you could have a 3.07 or a 3.73.
gear ratio = RPM XTire diameter divided by MPH X 336
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 03-08-2003, 09:13 PM   #4
Nova_Cobra64
Hehe, beat you by probably 10 seconds.
Old 03-08-2003, 09:33 PM   #5
john
member #16
john's Avatar
try this
http://www.angelfire.com/fl/procrastination/rear.html
john is offline   Reply With Quote
Old 03-09-2003, 12:48 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Or you could pop the cover off and chainge the 10 - 30 yr old oil and cout the teeth on the gears.
Old 03-09-2003, 06:56 AM   #7
ZOOMY
ratio
jack up the rearend & count the driveshaft revolutions it takes for the wheel on one side to make one revolution. On a non-posi, just jack up one wheel......
ZOOMY is offline   Reply With Quote
Old 03-09-2003, 09:39 AM   #8
da-burb
"Ochre Ogre"
da-burb's Avatar
...but count the drive shaft revolutions during 2 full revolutions of 1 tire to get the approximate gear ratio.
and I like to use the calculators at Randy's ring and pinion.
www.ring-pinion.com
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
