How to get to cab bolts
Ok this might be dumb question but hvae never done this befor! I got a 86 gmc body that im going to put on my 75 chevy frame. Was looking the cab over to day and how do you get to the cab bolts? Do i have to cut a hole in the floor?
Also dose some one have a wiring diagram on here? Im going to be lost when hooking this up to the new motor and frame Thanks
04 Chevy Duramax LLY crewcab 4X4 Built ATS Allison Upgrades ![]() 75 chevy 3/4 ton 4x4 its got a built 350 with dana 44 and a lift. |
yeller
Re: How to get to cab bolts
Cab bolts are accessible from underneath the cab.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
Robert Olson Transport
![]() Join Date: Oct 2002
the bolts go into the cab from underneath. they have a welded in piece that has the threads... if that is spun you have to drill into the floor to take em apart manually or use a blue tip wrench
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
US Army Veteran
![]() Join Date: Nov 2008
If you end up stripping these trying to get them out (we did...the squares at the top couldn't compete with thirty years of rust on the bolt and stripped out), get some 5/8 or 3/4 nuts and weld to the top of the bolts, then a long 1/2 inch wrench on the bolts at top/bottom should get them. We had to do that to get them out.
Nothing is ever as easy as it may seem on these old trucks!
1972 C10 Highlander - The making of a daily driver |
