02-15-2009, 02:37 PM | #1 |
rubber seals for blazer top
I had the top painted for my 72 blazer and now I need to put it back on, the problem is the front seal( above the windshield) I only want to glue it on once, not sure where it seals at though?. does any on have any pictures of the seal location, I want it to be an one time shot.
thanks |
02-16-2009, 01:01 AM | #2 |
2WD Jimmy
Re: rubber seals for blazer top
Hmmm... that is a good question. Its one I am going to have to face soon. I havnt even looked at the original one yet. I have two tops to choose from. A single and a double wall. Both tops are in pretty good shape, but will still need the dips on top straightened out. Im leaning towards the single wall, but I cant figure out how they can get the dips out without cutting and sectioning. What did they do on yours? How about posting a pic?
02-16-2009, 02:05 AM | #3 |
SKINNY TIRES RULE!
If you have the seal, it should be fairly apparent. If I recall, there are tabs that hold it in place near the corners and the sealt should "fit" into the groove. A quick test fit before applying the contact cement to both pieces should make it fairly easy to determine the proper placement.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
02-16-2009, 01:09 PM | #4 |
Mr. Vogal, I had my top smoothed out, no rough texture, as for the dips I still have some. I wasnt worried about them because it tall enough so they wouldnt be seen, out of sight out of mind.
