Old 02-16-2009, 10:40 AM   #1
NYC-10
screamin eagle
NYC-10's Avatar
radio options
before I hack my dash to install my radio can anyone give me a high quality alternative?and do not mention Custom auto sound.I am running 2 amps 2 subs 2 mids and tweets
SCREAMIN EAGLE
NYC-10 is offline   Reply With Quote
Old 02-16-2009, 01:07 PM   #2
Ace in the hole
Re: radio options
have you checked these guys out? http://www.retrosoundusa.com/
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 02-16-2009, 01:55 PM   #3
dan42
dan42's Avatar
Re: radio options
I have a retrosound in mine but you definitely need an amp, and am having a little problem organizing my music on a flash drive, but I don't think it's the unit, it's just me. It's an O.K. unit and better than custom sound, but not much, IMO. I'm not too crazy about the kickpanel speakers either. At any rate, I'll be looking to change things a bit, because it sounds horrible right now.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 02-16-2009, 03:02 PM   #4
Re: radio options
Mike Hagan Antique Auto Radio Repair
(215)547-7145
He can take any original radio and give it new 180w insides along with cd/XM/MP3 ready.It ain`t cheap,but the best way to stay original looking and get quality sound.
Old 02-16-2009, 04:20 PM   #5
brad_man_72
the boat guy
brad_man_72's Avatar
Re: radio options
factory am/fm in the dash, something that works hidden anywhere, under seat, glovebox ect.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 02-16-2009, 05:14 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: radio options
Check out mahanian, on the board. He has a really nice billet aluminum part that enables a DIN-sized radio unit to fit into the dash. I know, I know.....don't cut the dash is the mantra for a lot of folks. The only problem, and I'm sure you are aware, is that we don't have many choices when it comes to 2-shaft radios.
There was an extensive series of postings done on his part, so do a search and I'm sure you can find it. I bought one for my truck, which hasn't yet been installed (waiting until other work is done), but I'm gonna enjoy an AM/FM/CD unit when it's ready.
Member Nr. 2770
Old 02-16-2009, 05:35 PM   #7
duceducenine
duceducenine's Avatar
Re: radio options
heres what i do and i paint the sleeve black
probably not what your looking for but i wont
cut up a dash for sure not one with an a/c cab
duceducenine is offline   Reply With Quote
Old 02-16-2009, 05:39 PM   #8
big_al_71
big_al_71's Avatar
Re: radio options
Cut the dash and install a "Quality" radio. I just went thru this recently and I could not be happier.
I had one of those retro radios in my el camino and it was a POS it lasted me three months and it blew up.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 02-16-2009, 05:52 PM   #9
68gmsee
Active Member
68gmsee's Avatar
Re: radio options
Does anyone know who makes this one for Classic Parts?
http://www.classicparts.com/1967-72-...info/69%2D758/
68gmsee is offline   Reply With Quote
Old 02-16-2009, 05:57 PM   #10
71swb4x4
71swb4x4's Avatar
Re: radio options
The USA-6 is definitely a Custom Autosound piece.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 02-16-2009, 06:20 PM   #11
leddzepp
Moderator
leddzepp's Avatar
Re: radio options
I don't care what anyone says, Custom autosound rocks! I have had one for several years, and it works great. The people who don't like it are more than likely using $20 Kraco speakers. You cannot expect much if you do not use quality speakers.
Old 02-16-2009, 06:51 PM   #12
NYC-10
screamin eagle
NYC-10's Avatar
Re: radio options
I think I will cut the dash and save the pieces
SCREAMIN EAGLE
Old 02-16-2009, 07:44 PM   #13
68gmsee
Active Member
68gmsee's Avatar
Re: radio options
That's what I though but wasn't sure.
Which one did you get? I was looking at the one in the Classic Parts catalog pn# 69-758 for $234 and 240 watts of power. I'm not into a lot of loud music and big speakers but I figured with the extra wattage the quality would be better with some good speakers.
Old 02-16-2009, 08:17 PM   #14
cparman
sharp as a marble
Re: radio options
I installed one of the retrosound units in a Blazer. If I remember it has RCA jacks to connect front.rear and sub amps, PLUS a mini usb on the faceplate to connect your thumbdrive or IPOD.
cparman is offline   Reply With Quote
Old 02-16-2009, 10:49 PM   #15
thebrown83
thebrown83's Avatar
Re: radio options
What is the deal with not cutting the dash? its metal and can just be welded back if needed right? most people on here seem to think the dash is trash if it is cut, but it can be fixed like any other piece of metal. why do people not object as much to shaving the firewall and side markers and trim holes and stuff? aftermarket radios that require a cut dash are cheaper and just all around better in my opinion. just my 2 cents... really not trying to offend anyone.
thebrown83 is offline   Reply With Quote
