Old 02-17-2009, 10:46 AM   #1
LuckyHenriksen
LuckyHenriksen's Avatar
Best Way To Cut Hole In Bed
For an under bed fuel cell. I need to measure out the hole for the filler neck and cut it. What would be my best bet for cutting the metal? Can I put a cut off wheel on my grinder? Any tips for accurate measuring would be nice too
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 02-17-2009, 10:49 AM   #2
nartkers
nartkers's Avatar
Re: Best Way To Cut Hole In Bed
I am interested in the same info - I am planning to use a blazer tank.
nartkers is offline   Reply With Quote
Old 02-17-2009, 10:56 AM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
My advice on cuttimg would be to use a hole saw.Especially if you need a round hole.Even if you need some other shape a hole saw will give you a good place to start what you need.
As far as measuring I can only say measure,measure,measure and then measure again.Then stop and measure again.Measure from the top and the bottom and try to determine if the marks match.Then drill from the bottom(if you have a better veiw to make sure it's right)with a small bit.You can then use the hole for a guide to drill the main hole.
Don't forget to check for fuel,brake, or any other kind of lines that may be under the floor.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-17-2009, 11:27 AM   #4
cdowns
cdowns's Avatar
round hole=hole saw
square or rectangle jigsaw if you know how to use one for cutting metal or a cutoffwheel
Old 02-17-2009, 12:24 PM   #5
my67chevytruck
Under Construction
my67chevytruck's Avatar
mount the gas tank. get a piece of hose the same diameter you are going to use and install in on the gastank (trim it enough to flush with the bottom of the truck bed, and mark around the hose with a sharpie, use that as your template...
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 02-17-2009, 12:52 PM   #6
mr48chev
mr48chev's Avatar
+1 Great suggestion. you can drill a pilot hole in the center of the circle you marked and the use the correct size hole saw from the top or use that as the center to mark for cutting a hole with another tool.
The filler in the floor might be ok for a show only truck but I can say from experience that it gets to be a royal pain in the tailfeathers if you actually use the truck as a truck.
Old 02-17-2009, 04:25 PM   #7
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Use the force!
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 02-17-2009, 04:36 PM   #8
jbristo67
resident oilfield trash
jbristo67's Avatar
I ran mine through the back driver side inner bed side. I cut out of the bed side a 3 inch hole with a hole saw. Then I got a pice of 4 inch square tubing and cut it at a 45 degree angle. Then I welded a piece of plate on the flat end of the Square tubing and smoothed out the welds. Then I welded the angled side over the three inch hole. Then cut a hole in the plate on the flat end for my fuel filler. Then I plumbed it down the bed side and into my tank.
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 02-17-2009, 06:24 PM   #9
alfeefish
Do you have pictures?
alfeefish is offline   Reply With Quote
Old 02-17-2009, 07:42 PM   #10
Mike C
Mike C's Avatar
If you do it in the floor, you can stand on a piece of plywood to keep the hole saw from moving once you have it lined up. I had to do this with a 4" hole saw when I put my B&W turnover ball in my Duramax truck.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-17-2009, 08:54 PM   #11
jbristo67
jbristo67's Avatar
I will as soon as I get it back from the body shop.
2011 Nissan Armada
Old 02-17-2009, 09:02 PM   #12
texanidiot25
Eat My Rust
texanidiot25's Avatar
I just use my fists.
But you know, not everyone has fists of fury. Like me.
texanidiot25 is offline   Reply With Quote
Old 02-17-2009, 09:03 PM   #13
LuckyHenriksen
Sweet thanks guys. I wish I could use the force! This thing is tricky
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
