Old 02-18-2009, 01:38 AM   #1
jared78
jared78's Avatar
rear disc brake kit
Anybody have a rear disc brake kit that they like? I'm not looking to spend thousands, just mainly tired of looking at drums behind 20" wheels. I would like something that wouldn't require changing the fronts out right away in order to not look weird. Help me out.
jared78 is offline   Reply With Quote
Old 02-18-2009, 01:43 AM   #2
menace121978
menace121978's Avatar
Re: rear disc brake kit
subscribing, like to hear what others have done or plan to do...
theres a thread about the caprice disc set up on here w/ f body calipers but we need a template for the caliper bracket so someone can make them.
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 02-18-2009, 01:53 AM   #3
79blazer
79blazer's Avatar
I've heard of the Impala SS/Caprice 9c1 brake swap, that needs a custom bracket, but then I found this:
http://67-72chevytrucks.com/vboard/s....php?p=2988690
Gotta love GM interchangeability!
79 Blazer Cheyenne, 2wd 305 3.42 stock
85 Caprice, TBI converted, new 350 crate motor, Monte Carlo SS Wheels, Bilstein shocks,
79blazer is offline   Reply With Quote
Old 02-18-2009, 03:19 AM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Swap in a Lincoln or Caddy 5X5 rear end. Easy disc conversion!
Old 02-18-2009, 04:16 AM   #5
andrewmp6
Try here http://www.scarebird.com/index.php?id=1
Old 02-18-2009, 09:24 AM   #6
CoggedBelt75
CoggedBelt75's Avatar
WILWOOD DISC BRAKE KIT: #140-4545-B ..... Summit $486.95
CoggedBelt75 is offline   Reply With Quote
Old 02-18-2009, 09:59 AM   #7
cochino12
It followed me home?
cochino12's Avatar
Here is a link to the kit that TVBLAZER78 used
http://67-72chevytrucks.com/vboard/s...highlight=rear
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 02-18-2009, 10:05 AM   #8
crawdadfox
crawdadfox's Avatar
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
I think the one Travis used on his Blazer is the ticket.....cant beat it for the money!
crawdadfox is offline   Reply With Quote
Old 02-18-2009, 10:15 AM   #9
tvblazer78
Low & Fast!
tvblazer78's Avatar
Yep I like it...
tvblazer78 is offline   Reply With Quote
Old 02-18-2009, 12:04 PM   #10
jared78
jared78's Avatar
yeah that's pretty much what I'm looking for. I think I'll go to their site and check into getting one coming. Thanks for the info.
Old 02-18-2009, 12:25 PM   #11
Cherub
Cherub's Avatar
Originally Posted by tvblazer78 View Post
Yep I like it...
what caliper do they use? Are the brake pads and rotors common parts that can be picked up at the local Auto store? that would be my consern having to special order parts as they wear out.
Cherub is offline   Reply With Quote
Old 02-18-2009, 12:56 PM   #12
dooce
From the emails I have sent to Blackbirds, they say the only non-GM part is the custom bracket, so calipers, rotors, and pads should be easily available, not a custom part.
1976 Chevy 1/2T 2wd SWB
327/Saginaw 4spd 3.73:1
LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071
LFSalleeII@gmail.com
dooce is offline   Reply With Quote
Old 02-18-2009, 01:08 PM   #13
tvblazer78
Low & Fast!
tvblazer78's Avatar
He only uses GM parts, the calipers are the same size as your front ones on your truck and so are the pad. Same PN and everything..
Old 02-18-2009, 01:29 PM   #14
dooce
From what I understood, the bracket was custom, non-gm. Is this correct or did I misunderstand?
Old 02-18-2009, 01:35 PM   #15
Primer70
Superbad
Primer70's Avatar
* 95 Dodge 1/2 ton 4X4 front rotors redrilled to 5x5" lug partern $33.99 X 2 = $67.98 : http://www.partsamerica.com/ProductD...pe=221&PTSet=A
* Speedway Motors weld on caliper brackets $9.99 X 2 = $19.98 : http://www.speedwaymotors.com/1969-1...CKET,3348.html
* 73 Chevrolet C10 right front caliper $14.99 : http://www.partsamerica.com/ProductD...e=5003&PTSet=A
* 73 Chevrolet C10 left front caliper $14.99 : http://www.partsamerica.com/ProductD...e=5003&PTSet=A
* 73 Chevrolet C10 front caliper pads $16.99 : http://www.partsamerica.com/ProductD...pe=219&PTSet=A
* 73 Chevrolet C10 right front caliper hose $19.99 : http://www.partsamerica.com/ProductD...pe=228&PTSet=A
* 73 Chevrolet C10 left front caliper hose $22.99 : http://www.partsamerica.com/ProductD...pe=228&PTSet=A
Total $177.91
I have pictures on my computer at home, looks almost like it would have came from the factory with them. I did not set it up with a parking brake because my Suburban will be bagged & laying frame, it won't need it.
Speedway Motors also sells complete weld on rear disc brake kits.
Without parking brake: http://www.speedwaymotors.com/GM-COM...PACE,2000.html
With parking brake: http://www.speedwaymotors.com/Speedw...rake,1999.html
Primer70 is offline   Reply With Quote
Old 02-18-2009, 01:36 PM   #16
SBTork
Garage wrench
SBTork's Avatar
It looks to be the best to me too.......I may have to look into that
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 02-18-2009, 02:01 PM   #17
mike nutt
69fatmotor
mike nutt's Avatar
http://store.summitracing.com/partde...BK1325&FROM=MG here's some from summit racing
mike nutt is offline   Reply With Quote
Old 02-18-2009, 02:15 PM   #18
spr85gmc
spr85gmc's Avatar
Originally Posted by mike nutt View Post
ar these custom parts or can i get them from any auto part store this kinda sparked my interest.......
spr85gmc is offline   Reply With Quote
Old 02-18-2009, 02:40 PM   #19
tvblazer78
Low & Fast!
tvblazer78's Avatar
Yes the bracket is custom, that is the only part..
Old 02-19-2009, 01:43 PM   #20
Primer70
Superbad
Primer70's Avatar
Pic of my rear disc brakes. The Suburban stops on a dime now, brakes are much more responsive.
Old 02-19-2009, 04:02 PM   #21
wicked_sky_gazer
Living Legend
wicked_sky_gazer's Avatar
I may have missed this somewhere but i have all the front disk parts (calipers pads rotars ect) to use for the rear disk setup on an 81... is there anywhere to buy just the bracket? is that all i need.... sorry im a bit confused when it comes to brakes can i go that rout without changing the track width? angain sorry if the questions have been answered already..
'81 c10 sw 355cid roller motor 350turbo with stage two shift kit, poor rear end gearing, not sure peg speed... speedo is mia..
project is temporarily on pause again... Thankyou wonderfull economy.. check it out
Im not to worried i have an uncaning ability to save myself from some weeeiiirrd crap
East Ok meet East Ok date
Tony
wicked_sky_gazer is offline   Reply With Quote
Old 02-20-2009, 05:14 PM   #22
evan
evan's Avatar
If that worked for our trucks why don't they mention it on the website?
Evan B.
evan is offline   Reply With Quote
Old 02-20-2009, 07:22 PM   #23
spr85gmc
spr85gmc's Avatar
im confused
Old 02-20-2009, 07:40 PM   #24
elwoods76
Just Cruizin
elwoods76's Avatar
Does anyone that has used a kit have a template of this custom bracket? with the specs? I know a good machinist and would like to give him the specs to see how hard it would be to do. That way I could just get the other parts from the parts store and save some $$$. Thanks
elwoods76 is offline   Reply With Quote
Old 02-20-2009, 07:45 PM   #25
wicked_sky_gazer
Living Legend
Ditto I already have 2 extra front disk setups I just can't find anything on the brackets to buy or make them help would be great
Tony
