02-17-2009, 09:51 PM | #1 |
What years for a 5lug conversion??
I have a new toy, '67 Chevy swb. I need to convert to 5 lug. What years can be used? I know that the rearend has to be a 71-72, but what about the front disc brakes? Is it the same years or can you dip into the 80's? I was just wondering, I'm not so clear on this.
02-17-2009, 10:06 PM | #2 |
67-72 parts collector,…
Re: What years for a 5lug conversion??
71-87 pick ups.
71-91 burbs
02-17-2009, 10:06 PM | #3 |
Tot Roddin'
You can use the '71-72 models or jump up to the '73-87 models which will offer cheaper replacement parts.
I'll let some other members chime in as I'm not completely knowledgeable on the subject.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
02-17-2009, 10:07 PM | #4 |
Tot Roddin'
And look at that... lolife99 chimes in before I get a chance too.
02-17-2009, 10:14 PM | #5 |
Tot Roddin'
God I love this place!!!!
02-18-2009, 12:36 AM | #6 |
Thanks for the help, I was hoping to here that. I was thinking up to like 79 but that was it. I have a donor truck then, 83 chevy. I may try and use the rearend also, depending on the width. I can't seem to get my hands on a 71-72 rear. I can cut the perches off and reweld them.
02-18-2009, 07:17 AM | #7 |
You can allso use conversion 5-lug axles in your 6-lug rearend with 71-72 brake drums. (approx. $300 for the axles) Look at ECE or Summit Racing or Moser Engineering for these axles.
02-18-2009, 09:47 AM | #8 | |
1967 C10 SWB
Another easy and cheap way to go is just re drill the axles you already have. Take the rear-end to a good rear-end shop have them check everything, replace the fluid and seals, and re-drill the bolt holes, press in new studs and BAM!!! for the same price you are good to go with a re-end you know is good!!! Vex
http://67-72chevytrucks.com/vboard/s....php?p=3867053 Last edited by vexvader; 02-18-2009 at 09:49 AM. |
02-18-2009, 10:01 AM | #9 | |
After I posted that I remembered that a shop I deal with here in my town can redrill axles to any pattern for $50 a side. I pull the axles, and it will cost me a $100. Only thing I may do is swap the rearends in both '67's because this one will be the Tow Pig and the other a driver, and it has 4.11's, this one I bet is 3.08. |
