So I read the sticky about the disc brake swap and I didn't really see what I was looking for. So here's my question. I have a 60 gmc (torsion style) and I've got a bunch of leads on complete front ends (coil spring) is it possible and how hard is it to switch it over?? Thanks alot guys!
Re: quick disc brake question
you can just take the hole front cross member out of a 80 1/2 ton trucks and just in stall it in to your truck. remove your old x member and put the newer 1/2 ton x member in you will have to drill some new holes to make it fit. here are some pics of my 60 i did.
vinnie 1960 chevy c10 frame with a 1966 cab 2002 dodge intrepid r/t 2004 chevy 2500 4 door short bed |
60-66 Nut
Any 1/2 ton pickup or Suburban front suspension from 1971 to 1987 will bolt in with minor work. I've not done on in a torsion bar truck, but in the '63-'70 trucks you need to drill one hole on each side and elongate one hole on each side.
Thanks for the help guys. Im gonna try and buy a 73 front end from a guy that I emailed off of CL and see if he still has it. I'll store it til I can borrow my Dads garage then start tearin stuff off!!
so this is probably a no seeing as everyone goes to 5 lug. But is there any one that makes a 6 lug rotor for the 73 set up I'm looking to install?
#6 | |
#7 | |
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
