02-19-2009, 10:10 AM | #1 |
Need some an fittings
Looking to buy some used or left over AN fittings from a previous build or just some someone is trying to get rid of.
I need: For Trans. Fluid 6AN – (6) straight 6AN – (2) 90 degree For Fuel Line 8AN – (6) straight 8AN – (20 90 degree 8AN – (1) 3/8’’ barb end straight Also need 20ft of 6AN stainless hose 15ft of 8AN stainless hose let me know if anyone has any of the above or at least something I can make work Thanks guys
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio ..... 1971 CREWMAX Build.....at body shop for couple more years |
02-19-2009, 11:50 AM | #2 |
Re: Need some an fittings
I have the following:
3 6AN 90s 1 6AN 45 1 4' section of 6AN hose 3 1' section of 6AN hose I just sold a bunch of 6AN and 8AN hose at the swpameet last year. I don't recommend using SS rubber lines for fuel. The fuel will eventually eat away at the hose and the vapors will seep through the hose and stink up the garage. I switched to teflon lined hose and my garage doesn't stink of fuel anymore.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
02-19-2009, 12:21 PM | #3 |
So is the Teflon hose have a stainless covering?? Or is it like the blue push lock type of hose?
02-19-2009, 01:13 PM | #4 |
a good place for finding used fittings and hoses is racingjunk.com
02-19-2009, 03:45 PM | #5 |
The teflon hose is covered in SS braid just like the rubber hose. The overall diameter of the teflon hose is slightly smaller because of the teflon vs the rubber hose. But the teflon has a larger bend radius so you can't make as tight a bend. It is also more expensive.
It was worth it to me though. My wife was ready to kick the truck out of the garage since the smell from the fuel was so strong.
02-20-2009, 12:34 AM | #6 |
Machinist
http://www.musclemotorsports.com/aer...ne---ftgs.html
check this place out.......... I found it five or six years ago |
02-20-2009, 04:23 PM | #7 |
Wow those are some good prices. Nice find scatesracing!
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time Last edited by Wild83C10; 02-20-2009 at 04:24 PM. |
02-20-2009, 07:55 PM | #8 |
Machinist
glad I could help... I found that back in the dial up days....... 56k LOL. They also have "truck type traling arms" to I was thinking about ordering one to see if they will fit the 60s and 70s trucks???? only $50 Travis
