02-08-2009, 01:40 PM | #1 |
Shifter Handlle Question
I have a tilt column ('72) and I have added a Camaro style steering wheel. My shifter handle seems like its way out there. Is there any other options for a shorter shifter handle that would work? Thanks for the help.
It's Not Rust, It's Patina!! 1967 C 20 Large Window, 700R4, 283, Tilt, PS, PB.....A Rusty But Trusty Gas Hog 2008 Silverado LTZ 1500 4x4 |
02-08-2009, 04:08 PM | #2 |
Re: Shifter Handlle Question
i'm not sure .i have a 4 spoke camaro as well in my 70, some years ago i installed a late 70's van tilt and it has a much nicer shorter arm , i'm not sure if they will work in an older column
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car |
02-08-2009, 06:13 PM | #3 |
Could you shorten it up and rethread the end?
02-08-2009, 06:14 PM | #4 |
Moderator
Use a shifter from a van tilt. They are shorter, and work perfectly with a smaller steering wheel.
02-08-2009, 08:42 PM | #5 |
you can use a gm car shifter from the 70's and mayby as late as a 1990 caprice car. use a punch and bump the pin up and pull the shift lever out. you may want to grab the spring also.
Trueman |
02-19-2009, 11:50 PM | #6 |
Thanks for all the input. This is the type of lever I need. As you can see, this one is almost completely trashed!! I'm having a difficult time locating a van shifter (I think it would look best with my smaller camaro steering wheel). Will I'll need to go to a GM parts counter? Does anyone have any other suggestions??
Thanks for the help!!
02-21-2009, 03:19 PM | #7 |
ttt
02-21-2009, 03:26 PM | #8 |
Too Dumb To Know Better
Check out the Jeeps in the junkyard as well. They used alot of the same parts.
