Old 02-22-2009, 12:13 PM   #1
1971ChevyTruck
1971ChevyTruck's Avatar
Monroe-sensa-trac load adjusting shocks questions
I bought this set of shocks for my 71 stepside. The problem is that they are fully extended when I got them. What is the trick to install them?? I was thinking about using a floor jack to compress them. Any ideas?? Anyone ever used them?? I was also wondering if the springs would clear the axle. I had them hanging off of the top bolt and it looks like it will be really close.
1971ChevyTruck is offline   Reply With Quote
Old 02-22-2009, 12:34 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Monroe-sensa-trac load adjusting shocks questions
you could always unbolt the panhard bar (unless it is on there permanatly due to Illinois salt crews) and lower the rear to where they reach the shocks (uppers bolted on as you said).
If you are useing those as overload springs, as in planning on hauling a bunch or weight, be warned that they upper shock mounts have been known to rip off from this kind of add on.
Old 02-22-2009, 12:48 PM   #3
LONGHAIR
Like Andy said, it is easier and safer to stretch the suspension than to try to compress the shock.
Also to repeat, shock mounts were not designed to support any weight, so adding springs to them w/o reinforcing the mounts can lead to failure.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 02-22-2009, 01:09 PM   #4
Boog
laying low
Boog's Avatar
Maybe some helper bags might be a better choice.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 02-22-2009, 02:06 PM   #5
1971ChevyTruck
I'm not going to be hauling or anything. I just wanted to stiffen up the rear of the truck a little. Heck I might only drive this once a week if I'm lucky. Plus I though they look cool. Thats the main reason I went with them. lol
