Old 02-22-2009, 09:04 AM   #1
Larry S
Larry S's Avatar
vortec/ blazer tank
Heres what I have. A 1996 5.7 vortec sitting in the front of my frame, and a blazer tank kit in the back. The question is, should I use the sender that came with the tank kit to be the proper ohms for my factory 69 gauge, and install a frame mount fuel pump? If thats my best option what would be best pump to use? Thank you for your time.
Larry S is offline   Reply With Quote
Old 02-22-2009, 10:38 AM   #2
Gray Ghost
Gray Ghost's Avatar
Re: vortec/ blazer tank
Cliff tells me that I need an in tank pump. He said it will work fine UNLESS I let the tank go below 1/4 full. Then I will have fuel starvation problems.
He told me to get a newer Blazer tank made for EFI [w/ baffles] to eliminate all problems, so that's what I am going to do.
Since Cliff is an ASE certified mechanic who works on everything from Chevy's to exotics, I trust him over most others I talk to.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 02-22-2009, 11:12 AM   #3
Sammy
Check the OHMS on the sending unit it should be fine as long as it is of our year group. I used I think a delco pump. First installed on r/h fender well had problems getting it to reprime moved it to frame works great. Good Luck.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 02-22-2009, 12:02 PM   #4
extd56
extd56's Avatar
I used a 89 Blazer tnak in my 67 for my fuel injected swap and it works great.
extd56 is offline   Reply With Quote
Old 02-22-2009, 12:33 PM   #5
jbristo67
resident oilfield trash
jbristo67's Avatar
Pump needs to be in the tank. Thats what keeps the pump cool. In the tank for sure
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 02-22-2009, 09:33 PM   #6
Larry S
Larry S's Avatar
Its a 67-72 blazer tank with a 0-90 ohms sender.
Old 02-22-2009, 09:59 PM   #7
Skirkpat
Skirkpat's Avatar
Fuel injected engines should have pump in tank, always ! It may run with the pump on the frame, but you will put unneeded strain on the pump ( liquid is easier to push than pull) If you want to do it right put it in the tank with a baffle and sump if possible?, and it's a good Idea to NEVER let it get down to 1/4 tank.
Skirkpat is offline   Reply With Quote
Old 02-23-2009, 09:42 PM   #8
Larry S
Larry S's Avatar
The Blazer tank I have has never had gas put in it before, so I even thought about cutting another hole in it and mounting my 96 in tank pump into the tank and using it as strictly a fuel pump (the pump that came out of the truck the engine is from), and having the 0-90 ohm sender (that came with the tank) also as strictly a sender and plugging off the fuel like on it. I'm just thinking out loud but I know that pump is the adequate fuel pressure for the vortec because it all came from the same truck, and the 0-90 ohm sender will work my 69 gauge. I wish someone made an in-tank pump with adequate pressure for vortec with a 0-90 ohm sender to fit in the Balzer tank. I hope that make sense.?! Probably dont, Im tired.
Old 02-24-2009, 12:44 AM   #9
Gray Ghost
Gray Ghost's Avatar
Your best bet is to get a tank made for efi. The 89 blazer tank has the correct sender and pump.
Kelly
Old 02-24-2009, 08:36 AM   #10
JMac11
JMac11's Avatar
Larry,
That is what I am doing with my LT1 install. Bought a new tank with a new sender for my 72 Blazer. I am going to install a drop in pump with slosh pan in the tank, I will post a link for the one I have found. It is a little pricey compared to robbing one out of a Fi car. but I think the $100 is worth the safety. If I were going to use one from a donor car, the LT!/LT99 Caprice/Impalas look to be the right depth.
http://www.tanksinc.com/index.cfm/pa...prod/prd84.htm
JMac11 is offline   Reply With Quote
Old 02-25-2009, 10:15 PM   #11
Larry S
Larry S's Avatar
That is definitely an option. Thanks for the link.
Old 02-25-2009, 11:17 PM   #12
68C15
blood type; Retumbo
68C15's Avatar
no, it will not run a vortec engine. these need at least 58 PSI to start. any less and you will just run your battery dead.
I would have the tank modified to use the 96 pump module with the sender. they are the same range and direction for our gauges.
68C15 is offline   Reply With Quote
Old 02-25-2009, 11:27 PM   #13
67ChevyRedneck
67ChevyRedneck's Avatar
I've heard the "Don't let it get below 1/4 tank thing" MANY times. So, I took it to heart. Makes sense to me, more fuel = a covered pump surrounded by a cooler fuel. So in my silverado and my wifes corolla we don't let the fuel get much below 1/4 tank. I've read many complaints of the silverado fuel pumps dying early on other websites and mine has 118K on it and the 'yota is up to 112K. Not sure if I'm lucky or there really is something to that advice.
I'd recommend in tank as well.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-25-2009, 11:36 PM   #14
Gray Ghost
Gray Ghost's Avatar
That's only for the in tank pump without baffles. If you don't have baffles the pump can go dry if you turn a corner fast or slosh the fuel around too much.
The wife has a 98 S10 and we never fill it at 1/4 tank.
I guess I stand corrected on the pump part of the 89 Blazer tank. I am not an expert on EFI by any means. So what is the PSI of the 89 pump?
Kelly
Old 02-26-2009, 01:35 AM   #15
jorgensensc
jorgensensc's Avatar
So here is a really dumb idea, but think about this one. Get a small tank that ships with some trucks from the factory. It is like 3 or 4 gallons. If I remember it has a fuel pump in it. Put it in between the engine and the blazer tank (in line). Run a low budget low pressure external fuel pump from the blazer tank to the new tank. This keeps fuel in the small tank (swirl pot) at all times and keeps the pump from running low on fuel. the low pressure pump keeps it full. This is the way early fuel injections worked without baffles. Just an Idea.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 02-26-2009, 06:52 AM   #16
68C15
blood type; Retumbo
68C15's Avatar
an 89 pump (TBI) runs at 9 to 13 PSI. they were used from 87 through 95. then in 96 they went to multi port (vortec).
Old 02-26-2009, 07:50 PM   #17
Larry S
Larry S's Avatar
Yea. I was told that the 96 sender/ pump was a different ohm sender and my gauge would not be right. See Im using the wiring harness from the 96 silverado that the engine came out of. So that would be great if the sender was the same ohms. I could just modify the blazer tank to put that unit in it and it would be the correct pressure for the engine. Both senders are very close to the same height. I would like to use what I have, but its gonna have to work right.
