02-23-2009, 02:56 PM | #1 |
Help me find a part
I've just ordered my new transmission and the shop won't warranty it unless the kickdown cable is hooked up.
That means I need your help finding a kickdown (detent) cable bracket for an inline 6 250.... all stock for now. I think it's a mid 70's block with the separate head and intake manifold. if someone knows where a supplier has one for sale that would be great! Thanks! Last edited by N2TRUX; 02-23-2009 at 07:08 PM. |
02-23-2009, 03:15 PM | #2 |
Active Member
Re: Help me find a part
I would call a local wrecking yard that keeps some older trucks - they should be able to fix you right up.
That kick down cable also helps to control the fluid pressure in the case - important on a T350, critical on 700R4 and other over drive trannys.
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree |
02-23-2009, 03:37 PM | #3 |
Project '67 454
The shop should be able to sell you a universal kick down cable kit available from thier transmission parts supply house.
02-23-2009, 04:22 PM | #4 |
try gm dealership//summit jegs//bowtieoverdrives//help section local autoparts store
02-23-2009, 07:31 PM | #5 |
I did find one that I'm bidding on, but we'll see how that goes.
All of the boneyards around here seem to be stripped of anything in the engine bay. I'll try more of the aftermarket suppliers... so far all of the ones I see are for 4bbl carbs or v-8's Won't go to the dealer for anything... Plus I know I can find it used.... I don't need some fancy shiny bracket, just one that does the job. |
