Old 01-06-2009, 02:15 PM   #26
Ford Assassin
Ford Assassin's Avatar
Re: cadillac rear disc brakes on 70 truck
Will the Caddy disc brake brackets work for the truck 12 bolt?
Thanks!!
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 01-07-2009, 06:23 PM   #27
truckintexas
Smile Re: cadillac rear disc brakes on 70 truck
MickMc and 61Superman, you guys rock! This is exactly the data I have been trying find. I joined this site in 2004, but have been pretty much inactive until last week (long story). I am just learning how to use the board. Thanks for all the specific data! The year models and part numbers really help!!
truckintexas is offline   Reply With Quote
Old 01-07-2009, 07:21 PM   #28
tdave00
Restoring a 68 SWB
tdave00's Avatar
Unless there's already a more comprehensive writeup about this then I think it's a good canidate for the FAQ. I know I have it bookmarked .
tdave00 is offline   Reply With Quote
Old 01-08-2009, 03:55 AM   #29
powerbench
powerbench's Avatar
Sorry to jump in , but did the rotor or axle have to be machined to fit?
powerbench is offline   Reply With Quote
Old 01-08-2009, 08:24 PM   #30
61superman
61superman's Avatar
hey Ford Assassin yes it will work for the 12 bolt rear that is what i am running on my 72 burb
truckinTX and tdave00 thanks i am glad you guys are finding this info helpful. i have to say that this sight is awesome!!!
now Powerbench No there was no modification done to either the axle or the rotors its all stock caddy
thanks again guys
current project: 1964 chevy II Wagon
1956 3100
1972 c10 burb bagged
1962 GMC burb
1963 c10 burb
1966 c10 burb
1995 chevy lowerado 5/7 static drop daily driver
1963 c10 step side
1965 super sport impala
1967 c30
61superman is offline   Reply With Quote
Old 01-22-2009, 04:43 PM   #31
truckintexas
I ran across this on ebay today.........Rear disc BRACKETS for chevy trucks. I emailed the seller and he confirmed that these will fit 71-72 chevy rear ends. These looks alot like the CCP brackets (and others). This uses the seville calipers and rotors. I've never seen just the brackets for sale.......
I apparently do not know how to copy the link. Here is the ID. Ebay Item 310109374559
I will add the link later if I figure it out. Sorry, 1st time to try this.
Old 01-22-2009, 06:06 PM   #32
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Good info. Thanks 61superman & MickMC
LOW DOUGH is offline   Reply With Quote
Old 01-23-2009, 09:26 PM   #33
sweet70beast
sweet70beast's Avatar
I am running this same setup on my 70 Nova. As with the truck 12 bolts the backing plates will bolt up to the car 10 and 12 bolts. I had to machine the axle flange down alittle to fit into the rotor. I am using 79 Firebird rear rotors which are the same as the Caddy rotors except with the 5 on 4 3/4. Mine has mid 80's s-10 front calipers on my setup, they bolt up the same and use the same pads.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 01-26-2009, 06:58 PM   #34
theyammieguy
accepting donations
theyammieguy's Avatar
How are yall finding these parts? I live in Houston and I havent been able to find any oldd caddies
1999 Yamaha roadstar 1600 chop. (in progress.)
See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/
"Ya'll can go to hell, I'm going to Texas."
David Crockett
theyammieguy is offline   Reply With Quote
Old 01-26-2009, 07:53 PM   #35
61superman
61superman's Avatar
the hardest part to find would be the backing plates, but everything else you could buy at your local auto parts store. Otherwise it's just junkyards and swap meets
good luck
1956 3100
1962 GMC burb
1963 c10 burb
1966 c10 burb
1963 c10 step side
1967 c30
Old 01-26-2009, 08:25 PM   #36
theyammieguy
accepting donations
good luck
From what I've read, they rape you on the core charges.
David Crockett
Old 01-27-2009, 01:29 AM   #37
powerbench
powerbench's Avatar
hey superman, if i go off what that chart says your disc's are stagered(one facing front -and one back)
Old 02-17-2009, 11:47 AM   #38
dxevo
Superman, I just need to know if you had to modify the axle flanges. I found a set of rotors but they dont fit. the rotors I.D. measures approx 6in and the axel flanges are 6.5in.... is there a rotor that fits directly?
dxevo is offline   Reply With Quote
Old 02-17-2009, 08:43 PM   #39
Chevy4Life
Chevy4Life's Avatar
I'm using the caddy calipers on my 67. There was a member here who was sending out the templates for the brackets. I bought 2- 12"x12"x3/8" pieces of plate steel and carved them out with a cut off wheel and a grinder. It took time but it was cheap! I did need to tap a couple holes for the caliper bolts. Then I used 88 4x4 front rotors and turned down the axle hubs with a grinder for the rotors to slip over. Cheap and easy and they work great!
Jay
Chevy4Life is offline   Reply With Quote
Old 02-18-2009, 03:04 PM   #40
sick69
sick69's Avatar
Speedway sells the brackets aswell either bolt on or weld on for about 12.00 each along with the adapter fittings or an fittings.
Every place I have found rape you on the core charge. I just picked up the calipers on ebay for 65.00 shipped, so that may be an option for some.
Be very carefull about which rotors though. the 79 rotors have a 4 3/4 bolt pattern vrs the 77 with a 5" bolt pattern.
Ask me how I know! Anyone need a pair of 5x 4 3/4 rotors?
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 02-18-2009, 04:40 PM   #41
70STOVEBOLT
70STOVEBOLT's Avatar
Anybody know if there are 6-lug rotors that will work with this set-up?
I would like to make the conversion, but I don't want to swap the axles right now.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 02-18-2009, 06:51 PM   #42
tdave00
Restoring a 68 SWB
tdave00's Avatar
Blackbird Customs sells a 6 lug kit for about $400.
Old 02-24-2009, 12:40 PM   #43
truckintexas
CPP has the rear e-brake calipers listed on ebay for $110 plus $18 shipping, no core (including pads)
http://cgi.ebay.com/ebaymotors/Parts...1%7C240%3A1318
And here's a link for the brackets $87.95 plus $13.59 shipping.
http://cgi.ebay.com/ebaymotors/cc-CH...mZ310109374559
And here's the rotors from R1 Concepts @ $48.40 plus $21.82 shipping (for the pair).
That's a total of $299.36 for rotors, pads, brackets, and calipers.
Michael
Old 02-24-2009, 09:39 PM   #44
truckintexas
ttt
Old 02-26-2009, 10:39 AM   #45
70STOVEBOLT
Thanks Trai
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 02-26-2009, 11:23 AM   #46
72 SHORTBED 7.0
72 SHORTBED 7.0's Avatar
Michael
This is for 5 lug right^^^^ good INFo
72 SHORTBED 7.0 is offline   Reply With Quote
Old 02-26-2009, 11:32 AM   #47
truckintexas
Yes 5 lug, although I didn't even check to see if they had the 6 lug.....
Old 03-21-2009, 06:13 AM   #48
chuckmc8
It's alsways something.....
chuckmc8's Avatar
ANYONE BOUGHT AND INSTALLED THESE PARTICULAR PARTS TOGETHER?
Michael
chuckmc8 is offline   Reply With Quote
Old 03-21-2009, 12:09 PM   #49
justcuz
justcuz's Avatar
Hey Stovebolt, I would try the late model 4x4 front rotors on the rear. I am going to use them for a 4wd 4 wheel disc upgrade on my 93 Suburban. I see no reason why they would not fit on the older 6 lug axles. You just have to center the caliper on the rotor with your brackets.
justcuz is offline   Reply With Quote
Old 03-22-2009, 01:23 PM   #50
Burb
Coordinator of Synchronicity
Burb's Avatar
I am finishing up a 3/4 ton 14 bolt disc conv on my '71 Suburban and I used Cadillac Eldorado rear calipers w/ e-brake (bought on ebay), '71 4x4 front rotors, and I found a guy (via ebay) that used a waterjet cutting unit to cut some brakets to my specs, sent him the caliper and the bolt spacing for the rearend so I could bolt mount the brackets.
Looks good and is perfect for my 16" wheels
Rick
1971 Suburban ... W.I.P. Build Thread
Customization is ones personal touch-- not what other people think it should be
Burb is offline   Reply With Quote
