Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 02-24-2009, 02:27 AM   #1
The Big Green
need help with hotrod choice, S-10 Blazer, or truck???
Well, I wanted a box style truck, and I have a '91, but the wife got it lol. I have a '95 Blazer, my in-laws Blazer threw a rod. It is a 4.3 auto car, so I have a chance to get it back, it was my old Blazer. I'm not sure on the weight of this Blazer, it is a 4dr. I have an engine in a cc midsize truck, weight is 4500lbs and I'm wondering what the Blazer may be. I have a 550hp engine that needs something better than a 4500lb brick.
The Big Green is offline   Reply With Quote
Old 02-24-2009, 01:16 PM   #2
lvschevytrucks
Unfinished Project Club
lvschevytrucks's Avatar
Re: need help with hotrod choice, S-10 Blazer, or truck???
I just purchased a 1995 S10 Blazer 4 door 4x4 and the weight on the title is 4071lbs. No where near what you want
Handle every Stressful situation like a dog.
If you can't eat it or play with it,
Pee on it and walk away.
1996 Dodge Intreped ES Nice car great on gas
1993 Jeep Cherokee.
Looking for a swb chevy 73-87
lvschevytrucks is offline   Reply With Quote
Old 02-24-2009, 01:35 PM   #3
The Big Green
Thanks, I found a 88 S-10 truck I'm looking into. I think they are around 3000lbs, give or take a few hundred, I think I remember hearing like 2700lbs but not clear on that. If your 4x4 is 4000lbs then mine is a little under but thats still way to heavy and not worth it, but it is a nice Blazer, but not worth the time and trouble for the swap I had in mind.
Old 02-24-2009, 02:42 PM   #4
BarryB
BarryB's Avatar
Little trick to get those trucks to hook, is turning down the pinion angle on the rear I am thinking turned down 5-6 degrees.
Saw one that was built that had done to it. It just squatted and took off. ran 11. second on street tires.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 02-24-2009, 03:11 PM   #5
The Big Green
I had plans to do that, along with ladder bars.
Old 02-25-2009, 09:45 AM   #6
Jonce
Jonce's Avatar
Thanks for the tip BarryB, I will have to try that on mine.
My truck is kind of a tire roaster at the moment.
__________________________________
1971 GMC Stepside
350HO Deluxe 330hp, TH350 w/Gear Vendors, 3.73 Eaton posi, Fitech EFI, Boyd's Welding Tank, Ridler wheels, ECE 4/6" drop, front/rear sway bar
Jonce is offline   Reply With Quote
