Old 03-11-2003, 12:35 AM   #1
72gmcshorty
72gmcshorty's Avatar
Angry Cant get door to close....grrrrr
I am going crazy trying to get my door to close. I have new rubber on and I've had the striker and door mechanism powdercoated. I can get the door to strike the thing once but not the second time to fully close the door. I've put the striker all the way in, out, and inbetween with no luck. Anyone solve this?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 03-11-2003, 12:47 AM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Sometimes this can be solved by adjusting the hinges out. you may have to adjust the fender slightly. it depends on where it is hitting. You may have to readjust the striker if you move the hinges out. Just loosen bolts on door, not cab, and keep working it out and trying. Remember to tighten bolts before trying each time. Hope that works.
too much stuff is offline   Reply With Quote
Old 03-11-2003, 12:55 AM   #3
72gmcshorty
I've put the door hinges and the striker plate all the way out and no luck yet.
1992 Gmc 2wd
Old 03-11-2003, 02:14 AM   #4
casey
casey's Avatar
You might have to adjust the striker plate up or down as well, cause it might be binding abit, I know it's a pain in the a$$ I played with mine for a long time
casey is offline   Reply With Quote
Old 03-11-2003, 08:57 AM   #5
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
First thing to do is to remove the striker plate completely and see how the door feels pushed shut. It should have no binding and not be hard to fully close. If it does have trouble, you need to re-adjust your hinges to let the door sit away from the rubber a bit.
If it seems good, then the problem is in the striker adjustment itself. One thing I learned, a little goes a long way! Move slightly, test, move slightly re-test, keep going until it works good.
One other thing, the striker also has shims so not only can you adjust it in, out, up and down but also closer or further away from the cab jam. Lots of possibilities and that's why it's good to rule out the hinges by doing the above.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 03-11-2003, 09:44 AM   #6
1971LT1SWBPOSI373
1971LT1SWBPOSI373's Avatar
I experienced that problem about 10 years ago, and it was because I used an aftermarket door seal from JC Whitney. It was cheap and I was on a tight budget. The door fit like crap for about a year until the door seal took a set. Putting Armor-all on the seal helped by giving it a little lubrication. Hope this helps....
1971 Shortbed 350/350 w/ Posi-traction 3:73's
1996 Chevy Silverado
TJ in Springfield, Virginia
Likes old Chevy trucks
Drinks Miller MGD
1971LT1SWBPOSI373 is offline   Reply With Quote
