Old 02-26-2009, 09:08 PM   #1
lyrikz
PITbut
lyrikz's Avatar
Air baggers. Need help asap. Valve wiring?
I figured this was pretty straight forward. I have SMC valves. One red wire and one black wire per valve. I figured you ground the black wire and put the red to hot if you want it to open. That doesnt work, so before i keep screwing with it. How do you wire them? Is the black go to positive and the red to ground???
lyrikz is offline   Reply With Quote
Old 02-26-2009, 09:34 PM   #2
lyrikz
PITbut
lyrikz's Avatar
Re: Air baggers. Need help asap. Valve wiring?
No one??? I just dont want to mess up the valve. I cant see that the red wire would be for a ground and black for power...
Old 02-26-2009, 10:10 PM   #3
lyrikz
PITbut
lyrikz's Avatar
Well, just put the black to the negative on teh battery and the red to the positive. It works. I just dont get why it wouldnt work the way i had it. THe black grounded on the frame to bare metal and the red to the positive on the battery.. IDK...
Old 02-26-2009, 10:11 PM   #4
pissonNOS
senior member
pissonNOS's Avatar
stranger things have happened on my gc extreme valves the instructions werte wrong for the power and ground
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 02-26-2009, 10:11 PM   #5
firedog
firedog's Avatar
check out the suspension section you should find your answers there if not airbagit.com has good schematics drawn up
*SOLD*
1968 Chevy SWB Fleet
350/350 combo
Tach/tilt/buddy buckets
Bagged/18" Wheels
Black on Black
Project "Pandemic" the Farm Rat
1927 Chevy Capitol Truck Rat rod
'30 Model A Frame
Dual Carb 5.3 LS
http://www.67-72chevytrucks.com/vboa...d.php?t=804162
2007 GMC 4 DOOR 2WD
BUILT 5.3 STAGE 3 CAM 93 TUNE
LIFTED 22X12 WHEELS 33" TIRES
2023 Jeep RENEGADE
Wifes ride
firedog is offline   Reply With Quote
Old 02-26-2009, 10:46 PM   #6
Shane
Shane's Avatar
black to ground, red to power ...
Shane is offline   Reply With Quote
Old 02-26-2009, 11:23 PM   #7
lyrikz
PITbut
lyrikz's Avatar
I will look into it. THank you for the link.
Shane, i had the black wires grounded to the frame. Bare metal. I applied power to the red and nothing. Just doesnt make sense. I dont have my battery installed in the truck, so does that mean my frame is not grounded???
ONce i took the grounds off, hooked them to the negative on the battery, then the red to power, it works. Im just wondering why the darn frame grounds arent working.
Old 02-27-2009, 12:20 AM   #8
Shane
Shane's Avatar
If there is no battery in truck then there is no negative / ground on the frame. Once you reinstall the battery and ground it to the frame then you should be fine.
good luck!
Old 02-27-2009, 12:33 PM   #9
lyrikz
PITbut
lyrikz's Avatar
good luck!
I figured that out this morning. Thanks shane. I had my grounds all nice and neat and ripped em all out. ahaha. Oh well.
