Old 02-26-2009, 09:54 AM   #1
rddaves54
rddaves54's Avatar
Question water pump and paint question
The only water pump I can find has a plug in the top of it and the old one did not have this additional plug. Is there a place a water pump can be ordered that is like my old one within reason on cost? 72 Chevy 350V8
I was also wondering about the plug that controls the evaporative emissions control system canister because I am not putting it back on. When removing the evaporative emissions control system canister I have to remove all the vacuum lines and plug the gas line that went to the tank but I am not sure what to do with the electrical wire that plugs in on the right side of carburetor. Picture shows the solenoid I am taking about.
I am going to try my hand at using a gravity fed paint gun today using primer and want to know what the best material to clean the gun with would be. I am new and starting with the bed and with primer to see if and how it is and if I can do it.
rddaves54 is offline   Reply With Quote
Old 02-26-2009, 10:40 AM   #2
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: water pump and paint question
as far as the water pump, are you running a serpentine system? I ask because the only Water pump i have seen without the plug was on a serp. system. you can buy a plug to plug that hole if it is not being used.
Use laquer thinner to clean your HVLP gun.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 02-26-2009, 01:53 PM   #3
70 Suburban
Rods
If you let the paint dry you can use methelethelketone to clean it out
70 Suburban is offline   Reply With Quote
Old 02-26-2009, 02:34 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
I use lacquer thinner to clean my guns, when I am done. I buy the stuff from a local guy that sells it at a reduced price. I usually keep a 5 gallon can available in my shop. If you buy it by the gallon, from a supply store, the price is usually 3 to 5 times higher. I paid $25.00 for the 5 gallons that I now have.
Old 02-26-2009, 03:38 PM   #5
Green Machine
Green Machine's Avatar
Try Napa, just make sure the fan bolt pattern is the same. If you put an allen head plug in the top of the other ones they don't look to bad.
Trial fit the pump with gaskets first and check your pulley alignment with the crank. We have had to press the fan mounting collar on a little deeper on new or rebuilt pumps to get the pulleys to line up. Remove rear cover and just support the shaft while pressing the collar down.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 02-26-2009, 08:30 PM   #6
Sammy
MEK stay away from that stuff. Many aircraft mechanics in the last 10 years used that stuff for years. It has been proven the fumes are very toxic. Law suits, proved very cancerious. If you do use it, mask and eye protection the vapors are just lethal.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 02-26-2009, 10:42 PM   #7
70 Suburban
Rods
like mama said if it hurts it works
