Old 02-24-2009, 12:26 AM   #1
BigFatRedNeck
LQ9 In a 1970 Suburban
Has anyone put in a LQ9 into a 4WD Suburban? I'm going to mount it up to a 400 Turbo and was curious what type of issues to watch for. Motor Mounts? Cross Member placement. Transfer Case Linkage.
BigFatRedNeck is offline   Reply With Quote
Old 02-24-2009, 02:23 AM   #2
OldCreek
OldCreek's Avatar
Re: LQ9 In a 1970 Suburban
The great thing about putting it in a 4x4 is that you can potentially leave the t.c. in the stock location and then mount the motor anywhere it needs to be by sliding the mount forward or back.
Edit:
I dry fit sbc motor mount/diy4x4 first gen motor mounts today and they do not clear the oil pan. It looks like the 73+ mounts/crossmember clears just fine....
I was worried that there weren't enough threads about 4x4 GenIII/IV placements but it doesnt seem that big of a deal.
I should be mounting my LQ9 in my Blazer in the next week or so...then I can worry about all the other stuff...
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 02-27-2009, 12:06 AM   #3
sweet70beast
sweet70beast's Avatar
Dumb Question: What's a LQ9?
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 02-27-2009, 01:04 AM   #4
OldCreek
OldCreek's Avatar
Its a 6.0L GenIII LSx motor. Probably the highest output truck motor of that generation...correct me if i'm wrong. It's just like the LQ4 but with flat top pistons (not dished) so it has a bit higher compression and, therefore, rated for more hp/tq. Iron block, aluminum heads. Was found it the Heavy Duty line of GM trucks and in some Cadillacs.
Old 02-27-2009, 04:27 PM   #5
boostat4500
I have one in my burb right now. Actually it's on a stand in the garage, prepping the burb for paint, but it was in there for the previous 2 years. It's a pretty easy swap in a 4x. I ended up using my stock tranny x-member in the factory location. Truck was originally a 4 speed. The engine crossmember I made myself so I can't help ya there. Glad to help with any specific questions you have or problems you run into, just let me know.
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc.
boostat4500 is offline   Reply With Quote
Old 02-27-2009, 04:54 PM   #6
'63GENIII
'63GENIII's Avatar
I got my mounts from Summit. Haven't done the install as of yet, still have to send out the harness and computer. I'll be watching this thread. Money's kept me from getting more done. Your's should be a cool project!! Good Luck. Chris
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 02-28-2009, 12:10 AM   #7
AMD6769
how about some pics guys
AMD6769 is offline   Reply With Quote
Old 03-01-2009, 10:12 PM   #8
boostat4500
Here's a couple. Far from pretty, but got the job done. When it goes back in after paint, it will look much better!
Old 12-01-2009, 01:11 AM   #9
BigFatRedNeck
I dropped my suburban and LQ9 off at hillbillyhotrodz.com to have them properly mount the engine into the frame. I bought a couple of different conversion kits and nothing worked out for my talent level. I will post some pics after its complete and let you know how they did.
Old 12-01-2009, 08:58 PM   #10
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
That cross member almost looks like it is dropped enough to put a cummins in there. Very nice transplant there!
Ryan
1969 Chevy milk truck
Old 12-01-2009, 11:08 PM   #11
Critter
Future TOTM Winner
Critter's Avatar
I think you were spot on until your last sentence. The LQ9 (345 HP) was found in the Escalade, Chevy SS Silverado, and the Chevy/GMC Vortec Max, all which are "light duty" 1/2 ton platforms. The LQ4 (300-325 HP depending on the application) was the engine in the "heavy duty" 2500 and 3500 trucks, along with 3/4 ton Vans, GMC Denalis, 3/4 ton Suburban, 1500 HD, and the Hummer H2. Basically everything I said here is applicable for the older body style vehicles i.e 1999-2006.
By 2007 you start to see the LY6, L76, LFA, L92 which are similar but different.
...somebody correct me if I am wrong.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
1970, lq9, suburban
