Old 02-27-2009, 11:37 PM   #1
RED68SWB
RED68SWB's Avatar
Need Help
I just replaced my distributor, intake, and Carburetor and now my truck wont start. The entire electrical system is dead. I thought it was the battery, but it is fully charged. I dont even have lights. Is there something that I might have missed or screwed up?
RED68SWB is offline   Reply With Quote
Old 02-27-2009, 11:44 PM   #2
Sammy
Re: Need Help
Check your plug on the firewall in the engine department. Might have knocked that plug loose or its corroded. Everything gets power thru that connection.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 02-27-2009, 11:50 PM   #3
72blue
72blue's Avatar
Re: Need Help
clean your ground term. and the block connection. Grounds can cause lots of electrical demons.
72blue is offline   Reply With Quote
Old 02-27-2009, 11:59 PM   #4
RED68SWB
RED68SWB's Avatar
Re: Need Help
just checked it and its good. I dont understand it, it aint getting any power to anything.
Old 02-28-2009, 12:02 AM   #5
RED68SWB
RED68SWB's Avatar
Re: Need Help
Good Call. Ill clean it up and see how it goes.
Old 02-28-2009, 12:04 AM   #6
PHAT TONY
PHAT TONY's Avatar
Re: Need Help
Did you possibly short-out a fusable link?
PHAT TONY is offline   Reply With Quote
Old 02-28-2009, 12:07 AM   #7
RED68SWB
RED68SWB's Avatar
Re: Need Help
where is the fuseable link at? I checked the fuses under the dash but they are all good to go. Im a good wrench turner, but my electrician degree is still in the mail.
Old 02-28-2009, 12:07 AM   #8
El Jay
Gone to greener pastures
Re: Need Help
Beat me to it.
The fusible link can be blown, but look like it's blown.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 02-28-2009, 12:27 AM   #9
El Jay
Re: Need Help
I've seen them in 2 locations on GM trucks.
The 1st is a 16 Ga. (but with the heavier insulation, it looks like a 12 Ga. wire) wire from the battery to a junction block on the fender well near the battery.
The 2nd location is off the battery cable terminal on the starter solenoid. It too looks like a 12 Ga. wire.
If worse comes to worse, you can chase the wire backwards from the bulkhead connector for your fuse block.
Make sure everything is clean & shiny; battery posts, cable terminals at both ends, ground at the block, on & on & on.
A friend of mine had a similar problem. It was some corrosion in the bulkhead connector for the fuse block.
I had a problem that took me over a week to track down, & at that, I found it accidentally. The ground cable to the engine block was corroded inside the terminal at the block.
Good luck!
I hate electrical problems!
Old 02-28-2009, 12:28 AM   #10
PHAT TONY
PHAT TONY's Avatar
Re: Need Help
It's gonna be a softer section of wire, some kinda connector at each end, usually in the alt positive line or a starter line. It's a light inner heavy gage lookin and if burnt, it'll feel hallow inside. They're usually 3-4/5 inches long. Sorry to repeat, we're posting in unison.
Last edited by PHAT TONY; 02-28-2009 at 12:31 AM. Reason: Don't want to double post.
Old 02-28-2009, 12:39 AM   #11
Andy4639
Old member
Andy4639's Avatar
Re: Need Help
Check the + wire coming off the Battery to the fender at the block mounted on passenger fender make sure all the wires are intact. Then follow the wires across the radiator support. You will find the small fuses here.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-28-2009, 12:41 AM   #12
RED68SWB
RED68SWB's Avatar
Re: Need Help
Thanks for the help. I guess I got my day planned out for tomorrow. Hahaha, man I hope i get this figured out.
Old 02-28-2009, 01:53 AM   #13
El Jay
Re: Need Help
We're all working together to help each other.
