Old 02-12-2009, 03:49 PM   #26
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 6-lug to 5-lug questions,... (experts/gurus check-in)
Originally Posted by HuggerCST View Post
I understand why you want the narrow rearend, and I agree, but if you want to run that backspace/tire, I think the wider rearend is going to be what you need. I have the wider rear in my 70, and with 5 & 1/2" backspace, I only have about 1/2" of clearance between my tubs and tire. If I had the 1 & 1/2" narrower axle, they wouldn't fit, and if my math is correct, that's only going to give you 1/4" of clearance.(If you don't have too much tire buldge)
Good point! I will have to do some measuring. If that's the case,... I may need to use my 71-72 rearend after all.
Keith
Convert to disc brakes.
Old 02-12-2009, 03:55 PM   #27
lolife99
lolife99's Avatar
gcburdic,... I think I have the front stuff covered.
I'm using new McGaughy's 2.5" drop spindles ($100 swap meet bargain), and 3" Summit coils that I already had. Plus I'm throwing on the old rotors from the blazer with new calipers.
If you want to go ahead and post the link in here,... that would be great. I know alot of people ask questions about doing this swap.
My original intent was to swap in my 71-72 rearend,... until I got to thinking about using the narrow '69 rearend with conversion axles. Now you got me wondering about the backspacing.
So,... does anyone have a 5" backspaced wheel with the narrow 67-70 rearend?
Keith
Old 02-12-2009, 04:26 PM   #28
jbristo67
resident oilfield trash
jbristo67's Avatar
Originally Posted by gcburdic View Post
Hey lolife,
I think someone did a write up rebuilding the front suspension (including disks etc) with part numbers etc from a local auto part store....cost him like $600 for everything....I'll try and find it for you, unless you would rather go another route?!?!...I'll look for the thread....
Including my drop spindles new bearings and rotors and calipers i was right at 450
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 02-28-2009, 08:50 AM   #29
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
JBristo, you said you know a guy that has rear ends. do you have his name? I'm also looking to do a swap but on a 64.
Lowlife keep up the work, I've followed a lot of your threads. I didn't know there was so much diffrence in the lengths of the diffrent years. I'm just glad I found this forum before I start my build. I should dislike you JBristo just because you like Tech. But you like trucks so your cool!
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
