Old 02-28-2009, 11:13 AM   #1
backyardkustoms
backyardkustoms's Avatar
Help with removing my dash
Sorry if this is in the wrong spot but im trying to remove my dash in a 1970 c-10. MY question is do I have to remove my winshield I took all the bolts on the sides out and it seems to be stuck at the top and from what I can tell the lip of the dash goes behind the winshield molding. Any help you guys can give will be great. jack
backyardkustoms is offline   Reply With Quote
Old 02-28-2009, 11:16 AM   #2
Willys47
Willys47's Avatar
Re: Help with removing my dash
it is welded to the cab at that point at the windshield
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 02-28-2009, 11:17 AM   #3
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
I'm not 100% sure, but I thought the dash was spot welded to the top of the firewall @ the windshield molding.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 02-28-2009, 11:33 AM   #4
backyardkustoms
Alright thanks guys I just wanted to take it out to make the wiring job easier but i guess ill work around it thanks for the quick reply. jack
Old 02-28-2009, 12:18 PM   #5
Kayotic
Kayotic's Avatar
Yeah, and because of the angle where the spot welds are, it can get kinda messy.
I have a bare cab I removed on out of and still had a hard time.
Need to have the correct tools for the job, spot weld cutter or -
What's that other name = starts with a "B" i think?
After Thought: "Broach" or "Rota Broach"
Second Edit: Their from Blair Equipment Blair Equipment, Any thoughts? They do have a 1/4" available, seems mostly larger diameters...
Atlanta Craigslist
Hurst Indy Pickup Truck 3-Speed Shifter - 5010016
Kayotic is offline   Reply With Quote
Old 02-28-2009, 03:34 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I think the assembly manual shows 27 spot welds.
Member Nr. 2770
Old 02-28-2009, 06:54 PM   #7
bw4sale
bw4sale's Avatar
I drilled out 32 spot welds to get one out of a donor truck. Not fun.
BRENT
-'68 Stepside Project
-'98 Z71 Daily Driver
-Enough extra parts to build another truck and a half
bw4sale is offline   Reply With Quote
