Old 03-01-2009, 01:38 PM   #1
71HUGGER396
Confirmed Truckaholic
71HUGGER396's Avatar
Rear Axle Question
I'm getting ready to start working on my 1970 2wd Blazer. It has 6 Lugs, I was going to keep it that way, but I got a really good deal on everything I needed for the disc swap up front, the new stuff has 5 lug. What's the differance on some of the rear axles? I have a 1972 rear axle, don't won't to use it, it;'s very rusty. The axle housing under the Blazer is very nice. Can I just change axles shafts.
1968 50th STEP SIDE SHORTY, 350/350, a/c, ps, p,b
Daily Driver, 1970 Cst short fleet, all black, 350/350,
1970 2wd Blazer, 2wd, 6 cyl. 3 spd, original, now a 454, 350turbo, 3.73 posi, on the road
1971 2wd fleet shorty, 454, 700r4, 3.73 posi, SOLD to 67OLDSTYLE72
"My rig's a little old but that don't mean she's slow" - SAWYER BROWN's Six Days On The Road
SEMPER FI "I use to be a lean mean fighting machine, but now I'm a huffin, puffin, over stuffin love muffin"
71HUGGER396 is offline   Reply With Quote
Old 03-01-2009, 01:44 PM   #2
muddobber
muddobber
Re: Rear Axle Question
no 71 and 72 axleshafts are longer
muddobber is offline   Reply With Quote
Old 03-01-2009, 01:50 PM   #3
sameyrasmea72
sameyrasmea72's Avatar
I was thinking that the axles were longer in 1970.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 03-01-2009, 01:53 PM   #4
71HUGGER396
According to Early Classics catalog, the 1970 is the same as 1972. That is why I'm asking all the experts on the board.
Old 03-01-2009, 03:42 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
there is a good chance that the 70 is as long as the 71/72. There was a chainge mid year, it seems to be more of a chainge 1/4 the way through the year since more were wider than narrow.
Old 03-01-2009, 03:43 PM   #6
Green Machine
Green Machine's Avatar
1970 was a crossover year, some had the narrower rear and some had the wider rear, our 70 has the wider version.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 03-01-2009, 05:01 PM   #7
71HUGGER396
Can I just measure the housing or do I have to measure the axle shaft? What is the differance between the years?
Old 03-01-2009, 05:57 PM   #8
67_C-30
I have a radical idea!
67_C-30's Avatar
Just measure it from plate to and if it is the same as your '72 rearend, you're good. I know some 70's had the narrow rearend, but of the 6 or so 70's I've owned, all of them had the wide one.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 03-01-2009, 10:36 PM   #9
lts70
1970 Daily Driver
lts70's Avatar
If you have the “wide” rear end your axle will be 58.5" back-plate to back-plate, if you have the shorter rear-end it will be 57”. If you have the axles out the "wide" rear end axle shafts are 31.5" long, the "narrow" rear end axle shafts are 30.75" long.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
Old 03-02-2009, 09:35 AM   #10
71HUGGER396
Thanks for all you replies.
