Old 03-02-2009, 11:25 PM   #1
COACHMEASON
Keep On Keepin' On
COACHMEASON's Avatar
Moving gas tank to rear...
Moving gas tank to rear...Easiest way? Best way? Best filler spot? Anybody put it hidden behind pull down license plate?
Thanks for the suggestions
Clint
07 Avalanche Z71
92 Mustang 5.0 GT (Triple White w/ 53,000 miles)
72 SWB Chevy w/ PS, AC, 350/350
Current Project ....In paint shop getting body/paint work done (Corvette Velocity Yellow)...
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
COACHMEASON is offline   Reply With Quote
Old 03-02-2009, 11:31 PM   #2
lumpy81
lumpy81's Avatar
Re: Moving gas tank to rear...
I put a RCI fuel cell between the frame rails. My filler is an aviation cap on the bed floor. I don't know if this will suit your needs but it works well for me. Good luck.
death metal and hotrods
68 GMC SHORT STEP
35 CHEVY PICKUP
A FEW BIKES
SINNERS C.C.
lumpy81 is offline   Reply With Quote
Old 03-02-2009, 11:34 PM   #3
LuckyHenriksen
LuckyHenriksen's Avatar
hey lumpy can you post a pic of the av cap? I want to do something similar
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 03-03-2009, 12:21 AM   #4
Sir Fisher
Sir Fisher's Avatar
there's been many posts about this topic; here's a few recent posts...
http://67-72chevytrucks.com/vboard/s....php?p=3085225
http://67-72chevytrucks.com/vboard/s....php?p=3154200
and here's mine...
1970 Chevy K20 Custom Camper
1996 Chevy Impala SS
2008 Chevy Avalanche LT3
2003 Honda Accord EX
2001 Hewes Redfisher 16 Fighting Lady Yellow
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=324118
Sir Fisher is offline   Reply With Quote
Old 03-03-2009, 01:59 AM   #5
LuckyHenriksen
Sweet my threads in there lol
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 03-05-2009, 08:49 PM   #6
Kansas Tinner
Kansas Tinner's Avatar
After I swap my front drums for disc brakes, I intend on moving my gas tank to the rear also. I still dont know where i'm going to put the door. The bed floor would be the easier way but i think it would be a hassle with the tailgate down. Thinking about useing late model door on outside/ side of bed but i was thinking of putting it behind the license plate, hidden. I guess i wont know till i start the project.
Kansas Tinner is offline   Reply With Quote
Old 03-05-2009, 08:56 PM   #7
Sammy
Could be wrong. Have heard that behind the license plate won't work. As the tank is too high for the spout. Unless you put your tank lower than the filler tube. Would be about 4 inches off the pavement??
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 03-05-2009, 09:46 PM   #8
Kansas Tinner
Thanks for the info :gmc2
Old 03-05-2009, 10:09 PM   #9
LuckyHenriksen
Someone on here used a tank from a 1st Gen F body, and it worked well as far as I know. It looked sweet, and the filler was behind the license plate
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 03-05-2009, 10:20 PM   #10
msgross
msgross's Avatar
I had an aluminum tank made, going to put a flush mount marine style filler in the wood floor or just a flip door to the cap on top of the tank...
I thought about the Summit RCI tank that they have...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-06-2009, 02:38 AM   #11
spinning wheels
spinning wheels's Avatar
What are you guys using for the sending unit? I have been planning on doing this to my truck for the last seven years, but I don't drive it much.
I just hate the wasted space, that the stock gas tank takes up, behind the seats.
I have a 100 gallon tank, previously used for diesel oil, that I can convert. I would need to mount it across the bed.
I also picked up a 20 gallon aluminum tank that can sit across the front of the bed. The problem with these two tanks is, should I need to load up one of my bikes, the bike might have too much weight on the tailgate.
As for gas tank filler, personally, I like the behind the taillight filler.... So cool.
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 03-06-2009, 07:24 AM   #12
msgross
msgross's Avatar
you can find sending units for generic tanks at JC whitney or brothers for about $30. 90 OHM unit for the 67 and up trucks. SOme of the SUmmit tanks comes with one already.
That behind the light filler is cool, so is the marker light filler and stake hole filler.
The Garage:
Old 03-08-2009, 02:13 AM   #13
Mondo
Mondo's Avatar
Best to just buy a kit like this and concentrate on where you want the filler cap to be.
http://www.brotherstrucks.com/prodin...number=GTPDS72
Mondo is offline   Reply With Quote
Old 03-08-2009, 02:49 AM   #14
Texasbigblock
Texasbigblock's Avatar
i used a 69 camaro tank with the filler behind the liscense plate, works great, looks clean
-Scott-
1970 C10 shortbed 396
1969 C30 dually flatbed "Vidalia"
Texasbigblock is offline   Reply With Quote
Old 03-08-2009, 11:33 AM   #15
Ram-Man
Ram-Man's Avatar
These are about $110 from Summit and come with the sender. I'm not sure about a fill spot yet but most likely a lift open spot in the bed. I just bent up some 1" flat for some straps and some 1" square across the top for upper support.
Porterbuilt 8 Lugger
http://67-72chevytrucks.com/vboard/s...d.php?t=691739
Ram-Man is offline   Reply With Quote
Old 03-08-2009, 12:08 PM   #16
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
ram man, so the tank in that pic up there is from summit for 110$?
comes with sending unit and mounting straps and is a bolt in installation besides the filler?
what do you gotta do, extend the fuel lines, and make a filler? thanks
John
1999 Toyota Tacoma 4x4
Old 03-08-2009, 06:57 PM   #17
Ram-Man
Ram-Man's Avatar
The price is approx I bought it a year ago. It comes with the sender but the straps and upper supports I made. It is just a drag cell that they sell. Basically about the right size to fit right in.
Old 03-08-2009, 07:00 PM   #18
pissonNOS
senior member
pissonNOS's Avatar
i bought the cpp aluminum tank and was overall pretty happy with it
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 03-08-2009, 07:03 PM   #19
Ram-Man
Ram-Man's Avatar
I was off a little on the price its $144 with the sender and $116 without.
Here is the linky
http://store.summitracing.com/partde...5&autoview=sku
Old 03-08-2009, 07:15 PM   #20
mas09ts
mas09ts's Avatar
can you any more pictures of the tank? sender, spout?
Mitch
22yrs. Young
1970 GMC Short-Step 350/TH350 Combo. . . . Sold Dec 2011
Current Project 68 Gmc "Second Chance"
Go to my 68 GMC Shorty Rebuild Thread
http://67-72chevytrucks.com/vboard/s...39#post6341739
mas09ts is offline   Reply With Quote
Old 03-08-2009, 07:17 PM   #21
oldblue1968chevy
144 with sender and straps..didnt see anything about the straps on the site?
what're you gonna do for the extended lines? on a lwb could you order lines for a suburban that'd bolt up?
John
Old 03-08-2009, 08:58 PM   #22
Ram-Man
Ram-Man's Avatar
1 more time. I made the straps and supports on the top. Why not just bend some new lines. You can buy straight ones from any parts store pretty cheap.
Old 05-11-2009, 03:27 PM   #23
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
Texasbigblock pm sent
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 05-11-2009, 04:18 PM   #24
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I bought an ECE rear mount tank in 2003 and still haven't installed it yet. Was gonna pay someone to remove the box nstal the tank and do all the fabbing for the "behind the left rear running light filler " but I am going to attempt the install myself. Does anyone know if I just remove the wooden ( which is shot) floor would I be able to manoeuver the tank and crossmember replacement without removing the box. I also have Integrated seat belt seats from a 2003 Chevy to go in once I get the in-cab tank out.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 05-11-2009, 04:39 PM   #25
vasquezmrysvll
"the other guy"
im trying to get more info from Texasbigblock about installing a 1st gen fbody tank in the rear.
