![]() Join Date: Feb 2001
condensation in garage-how to stop???
Well, I restored the frame of my 72 Cheyenne Super last fall and it's been sitting in the garage all winter. I pulled it out today when I was Spring cleaning my garage and noticed surface rust on new bolts and on a few spots where the paint was thin. I've noticed when its cold and rainy that some metal objects in my garage get moisture on them. It's a basic A-frame 30X30 with loft on a concrete slab. There was no plastic put under the concrete - just poured on gravel. How can I stop the moisture - mainly on the truck? Would a large rubber mat under the truck help? Thanks for any help.
Joshua
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track 72 Cheyenne Super swb. 350/350 A/C, bucket seats 72 Cheyenne swb. Factory 402/400, tilt, posi, A/C 72 Cheyenne Super K-10. 350/4 spd., posi. 72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack 72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior |
Just like to part out trucks!!
Re: condensation in garage-how to stop???
I just had to put vents in my roof, soffets and gable ends and also been running a dehumidifier to get condensation out of my garage, its 27x24 with an insulated ceiling and walls. I'm running natural gas heat in it and man it was getting wet everywhere, after I put the vents in I've had no problems
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
Off Topic: Hey Joshua ... found a pair of backing plates today at Pitt's.
How`s the grade around the building?If water can get under the slab it will want to come up through.That`s the main source.The other is condensation from difference in temp in & out.Dehumidifiers help,but need draining.Air flow helps alot.I blow a small fan on my Harley just to keep moisture from settling on it.Heat takes it away,too.But,just a cieling fan helps.
Rottenwood Garage Member
Make sure the water is running away from the structure, keep the air moving inside and you will probably need to get a dehumidifier. and keep itt running
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
dang its hot
if it isn't heated and stays cold , it will sweat when warm temps hit cold objects
Active Member
![]() Join Date: Jul 2007
Mine is real bad about it. A lot of garage moisture problems are caused by water seeping up through the concrete and, of course, condensaton.
Also, most of them don't have a vapor barrier under the foundation like home slabs do -especially if they're detached. I saw a show on t.v. where they went in and sealed the concrete with a kit. If I was planning on staying in my house longer I would probably seal mine. |
~Rest In Peace~
brillant good knowledge
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
Thanks for the help so far. I left out some some info - it's detached and not insulated with a ridge vent on the roof. Nothing in my attic gets wet - just the stuff downstairs.
JQ
Do you have electric?You need circulation.If you can ad ventiation in the walls below the attic,that would be good.
Joshua,
Anything which you put on the truck which isn't painted will rust eventually ![]() B |
if you use good stainless bolts they dont rust
CDowns,
You're right, but for important bolts, I'm worried about the difference in shear properties between schedule 8 and stainless. |
