Old 03-05-2009, 12:39 PM   #1
Daves72'GMC
Question spare tire and carrier?
I have a 72' 3/4 and which way should the spare tire face under the truck with the carrier in place? Should front of the wheel be up or down towards the ground? Thank you.
Daves72'GMC is offline   Reply With Quote
Old 03-05-2009, 01:34 PM   #2
425HP409
425hp409
425HP409's Avatar
Wink Re: spare tire and carrier?
As a general rule, the spares usually mounted with the outside down so you could get to the valve stem to check the air pressure and add air as needed with the tire mounted under the truck.
Charles
425HP409 is offline   Reply With Quote
