Old 03-05-2009, 08:41 PM   #1
Knothead
Knothead's Avatar
Homemade Bed Wood
Finally completed cutting ,sanding & finishing wood for the bed. Old Chevy Manuals Online & MAR-K both have all the information needed to make your own.
Knothead is offline   Reply With Quote
Old 03-05-2009, 08:49 PM   #2
blackdiesel
blackdiesel's Avatar
Re: Homemade Bed Wood
Very nice work. Not for sure on what kind of wood, cherry? What kind of finish did you use.? I used automotive clear coat on mine.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 03-05-2009, 09:02 PM   #3
Knothead
Knothead's Avatar
I was told it's Mahoghany wood ,I used spar urethane for the finish. I happy with the way it all turned out , especially with what I got invested
Old 03-05-2009, 09:21 PM   #4
mr48chev
mr48chev's Avatar
Very nice.
Old 03-05-2009, 09:22 PM   #5
stan3018
nice i will do the same...
stan3018 is offline   Reply With Quote
Old 03-05-2009, 09:57 PM   #6
blackdiesel
I would say that mahoghany is right. Did you finish all the way around the boards?
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 03-05-2009, 10:08 PM   #7
Knothead
Knothead's Avatar
Yea ,they're sealed 360 degrees
Old 03-05-2009, 10:28 PM   #8
gmcer
Looks good I plan on doing the same I have some cherry left over from an old project
i
gmcer is offline   Reply With Quote
Old 03-05-2009, 11:46 PM   #9
50adrod
50adrod's Avatar
did you stain it first? just curious clear would react to the oil based stain.
1971 Corvette convertible 454@ 525 hp
1936 Chevy Truck street rod
1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up
1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html
1950 custom Chevy Truck
50adrod is offline   Reply With Quote
Old 03-06-2009, 12:36 AM   #10
blackdiesel
http://67-72chevytrucks.com/vboard/s...d.php?t=323944
check this thread out for pictures of my bed that i made. p.s., no stain
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
