Old 01-29-2009, 06:00 PM   #1
gdink1970KS
Calling all smoothed firewall
I am interested in doing this on my project.... I searched and couldn't find a real good place for info... I would also like to move the booster off the fire wall if possible.. like i said i could find exactly what i was looking for thanks
1970 Chevy X 2
2002 Chevy 1500HD
1990 Dodge Ram 50 (Gas Gitter)
gdink1970KS is offline   Reply With Quote
Old 01-29-2009, 06:10 PM   #2
wHATANERD
wHATANERD's Avatar
Re: Calling all smoothed firewall
Installing a Hydro Boost setup would remove the booster from the firewall.
1969 C/10 Longbed undergoing rebuild.
Old Chevy's Never Die, They Just Rust Around The Edges
wHATANERD is offline   Reply With Quote
Old 01-29-2009, 06:44 PM   #3
big_al_71
big_al_71's Avatar
Here is a pict of mine hope it helps..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 01-29-2009, 06:55 PM   #4
68 short step
here is one that im currenly working on for member 71 hulk, its smoothed and symetrical....the master cyl. is under the dash with a mounting bracket i made and a 90* pedal assy.
68 short step is offline   Reply With Quote
Old 01-29-2009, 07:09 PM   #5
ebfabman
Not a firewall but how about a smooth cowl/kick panel. This is rob32472's. Check out his build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=317665
ebfabman is offline   Reply With Quote
Old 01-30-2009, 09:21 AM   #6
68Stepbed
68Stepbed's Avatar
I still have the booster, but here's how mine is.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 01-30-2009, 07:09 PM   #7
gdink1970KS
wow... thanks guys... looks SHARP... 68 short step is that going to be a boosted setup??
1970 Chevy X 2
2002 Chevy 1500HD
Old 01-30-2009, 07:22 PM   #8
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
So I have a question for you guys with the shaved firewall setups.
Did you do away with your heater all together?
I would like to have this nice smooth look on mine but still have at least a heater and possible an A/C setup later.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 01-30-2009, 07:36 PM   #9
mbgmike
We sell these for 67-72 trucks if interested they are 18 guage
mbgmike is offline   Reply With Quote
Old 01-30-2009, 08:22 PM   #10
Kayotic
Kayotic's Avatar
mbgmike, Is that a replacement or an overlay?
Atlanta Craigslist
Hurst Indy Pickup Truck 3-Speed Shifter - 5010016
Kayotic is offline   Reply With Quote
Old 01-30-2009, 08:29 PM   #11
mbgmike
They are replacements but kind of both. There are actually 4 pieces to them. the firewall and floor pieces are replacements but the piece that goes on the cowl above the firewall can be welded on as a replacement or overlaid also but I would weld it in.
Old 01-30-2009, 08:48 PM   #12
boostat4500
mbgmike: PM sent on that firewall
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc.
boostat4500 is offline   Reply With Quote
Old 01-30-2009, 08:51 PM   #13
big_al_71
big_al_71's Avatar
I do have A/C but I do not have a heater being that I live in Florida I did not feel like I needed. Here is a pict of how we ran the A/C lines..
Old 01-30-2009, 08:53 PM   #14
big_al_71
big_al_71's Avatar
A/C lines
Old 01-30-2009, 09:00 PM   #15
boogie67
boogie67's Avatar
Heres mine.Im using a heater blower off a forklift for heat.I ran my hoses the same way Big al did on his truck.
77 swb starting all over again.
boogie67 is offline   Reply With Quote
Old 01-30-2009, 10:50 PM   #16
C20-67_N_MO
Big Al what A/C setup did you go with?
And I like how clean the firewall still looks!
Good Job!
Old 01-30-2009, 11:34 PM   #17
big_al_71
big_al_71's Avatar
Good Job!
Thank you
I went with classic auto air...
Old 01-31-2009, 01:24 AM   #18
Raguemoe
Junior Member
Raguemoe's Avatar
My 72 project firewall!
Raguemoe is offline   Reply With Quote
Old 01-31-2009, 04:09 AM   #19
greygoose
greygoose's Avatar
Where are you guys running the wires from or through?
If it ain't a chevy,I don't want it
greygoose is offline   Reply With Quote
Old 01-31-2009, 11:04 AM   #20
68 short step
yes it is a boosted set-up.....it is all electric, it has a small electric motor to boost the fluid pressure......
no, not at all....on most after market kits, they have both heater and a/c controls....
Old 01-31-2009, 11:25 AM   #21
big_al_71
big_al_71's Avatar
In my truck the wires are still in the stock location on the firewall, however they were all extended and ran behind the lh side fender all the way to the bottom of the radiator support.
Old 02-17-2009, 02:53 AM   #22
harvilljacob
69
harvilljacob is offline   Reply With Quote
Old 02-17-2009, 08:49 AM   #23
68Stepbed
68Stepbed's Avatar
I used an aftermarket wiring harness. The light harness comes out just behind the inner fender. The engine harness comes out just behind and below the top of the engine. It noticeable, but not obvious.
Matt
Old 03-07-2009, 11:18 PM   #24
monte0185
monte0185's Avatar
Im interested in this as well. Can you get just an aftermarket heating system? I dont really want A/C.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 03-07-2009, 11:31 PM   #25
XXL
Seņor Member
XXL's Avatar
Pics of mine done a few years ago. MC/booster, fuse panel, etc., are under the dash. The last pic is of my heater.
XXL is offline   Reply With Quote
