Old 01-22-2009, 09:44 PM   #26
Mike C
Mike C's Avatar
Re: 3/4 ton axles
In '67 4x4 half tons, I have seen Dana 44's in BOTH ends! So half ton rears would be Dana 44 or 12 bolt for 69-72 and 12 bolts 73 through '80 or so, and 10 bolt through '87. Rears would have been either Dana 60's or Eatons in 3/4 tons 67-72. As above, 14 bolt DID NOT show up until 73. I know where a one ton 4x4 is with a Dana 44 front, so it must be a 76 or earlier? I have an '86 one ton dually that has a Dana 60 front, but it has a Dana 70 rear. The 14 bolt dually rears were in cab and chassis trucks, the Dana 70 in pickups.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-07-2009, 08:11 PM   #27
eric67m
eric67m's Avatar
Re: 3/4 ton axles
Lots of great info in here.
Im bumping it to the top and subscribing to this thread.
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job"
eric67m is offline   Reply With Quote
Old 03-08-2009, 12:55 AM   #28
skchevota
skchevota's Avatar
Re: 3/4 ton axles
Well lets keep the hi jack going....I picked up a front axle out of a 2002 f250 superduty with the 7.3, and low and behold it is a dana 50. It looks the same as a 60 untill you pull the cover and find a smaller ring gear. I dont know if 2002 was the last year or if there are more.
skchevota is offline   Reply With Quote
Old 03-08-2009, 09:01 AM   #29
FormerMember
Re: 3/4 ton axles
I said it earlier in the thread. 2002 was the last year for the D50.
FormerMember is offline   Reply With Quote
