Need help: 2 piece D-shaft question
I have a '67 swb Chevy, and I need a 2-piece for suspension purposes. I'm bagging and don't want to cut into the cab. Question is, could I get one off a longbed or something? I just need the 2-piece, not sure where the guy want the joint, but I wonder if I can get one from a longbed and cut it, may be cheaper. I have a 68 GMC longbed truck.
Re: Need help: 2 piece D-shaft question
I need to know this too. I have a one piece as well, and have figures that depending on the motor placement and the tranny it will depend on how much I have to notch the cab. I'd rather just run a 2 piece and be done with it, but done even know where to begin looking. Bump cause I'm interested too
Old member
After reading both of ya'lls post I'm confused, which doesn't take awhole lot to do, but why do you think a 2 peice drive shaft will help you?
The only thing it will do is give you more up and down travel from the center bearing to the rear axle. The front half will still be at the same level as the transmission, and it will be stationary through to the center bearing. Can you give a little more info on what you are wanting to do. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
With a bagged truck that is laying frame, the rear of the cab gets in the way of the driveshaft when laid out if you have a one piece driveshaft. You can notch the cab, and how much will depend on rear tire size and re type of thansmission, as some of the tailshafts are longer than others. With a 2 piece shaft, the carrier bearing can be placed at the rear of the cab, and the axle can articulate without the driveshaft going up into the cab.
It makes sence in my head, so I hope it clears it up for ya. Sometimes things don't come out like I would want them to. Ha! Last edited by colin_havens; 03-08-2009 at 06:04 PM. |
Old member
OK that's what I was hoping you where talking about. If that is the case then yes a 2 peice should be just what you need. Put the drive shaft in the transmission and see where it needs to go and have cut lengthened. Have the cross member moved to mount the bearing and it's done. You may run into a problem driving it with it layed out though with a lot of angle in the u-versals.
I myself have a 350t long tail tranny and in my case, my D-shaft will get into the cab, and possibly in the floor of the truck itself. I will have measurements on my 2-piece in a few days when we can get to it. I have a longbed truck which I believe has the 2-piece parts I need. I may be able to rob stuff from it. I don't believe my angle when laying should affect anything. I'm hoping the angle won't be to bad, if so I'll run 2 U-joints behind the carrier bearing to help that.
Old member
I have a factory two peice sitting in the garage I can measure for you. I'm fixing to take it and have cut for my truck and have all new bearing installed.
I have the one in it now but the center bearing is causing a lot of vibes in the cab so I have this other one I'll have done and it will be a back up. I'm just going to swap them out and I'll take the other one later on when funds allow. ![]()
the boat guy
it might be cheaper th have one built than hacking on an old one, instead of mixing and matching specific slips stubs tubing size. have a driveline shop build you something out of new rediliy available parts? than make the 2 pieces whatever lenth you want/ make rear shaft as long as possible for better angles.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
Ill get my measurements tomorrow and have it cut. We need it to make the crossmember for the carrier bearing.
http://www.iedls.com/page4.html
Check out this link, Inland Empire driveline, they custom build a 2-piece that is bomb proof, they have an ordering guide in there as well to help you get the correct measurements from the correct places. |
