Old 03-10-2009, 10:00 PM   #1
fdbdw
fdbdw's Avatar
sway bar question
71 c10 LB,
Just put on a new front sway bar, shocks, wheel bearings and new ball joints, after reading a few posts on sway bars I was excited to get it mounted, I have to admit Im a little dissapointed, I dont notice that big of a difference with the sway bar added. the end link and frame bushings are rubber and Im wondering if getting urehtane bushings will make a difference and, If I can find a pick and pull, adding a rear sway bar will help (rear coils on this truck) Ive trippled checked and I know Its mounted correctly. Any opions will be great. ( maybe I was just expecting to much)
fdbdw is offline   Reply With Quote
Old 03-10-2009, 10:05 PM   #2
Andy4639
Old member
Andy4639's Avatar
Re: sway bar question
First off, what size did you install? Secondly yea you may have been expecting more than you got. I have both on the 71 and it's not no race car but it does handle nicely though.
I bought the front truck bar and did the Camaro rear bar.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-10-2009, 10:06 PM   #3
Security guy
Security guy's Avatar
How is the rest of your suspension? I've got a sway bar on the front and it handles like a go cart, but my whole front end is brand new also. Your sway bar may be helping, but if the rest of the suspension is wore out, its fighting against itself. Jack the front end up and pull on and shake everything to see if theres any play in it.........Just seen you replaced ball joints and bearings....maybe you did expect to much? Just trying to help.
Security guy is offline   Reply With Quote
Old 03-10-2009, 10:08 PM   #4
powell72
powell72's Avatar
I added a bar to one of my trucks and was very pleased with how much it helped. It was a BB truck, so there was some weight up front moving in the corners. I did the poly bushings at the time of install also. My current truck had a bar on it already and I put poly bushings in it also and didn't notice a difference from just that.
I don't know maybe you were expecting to much, it is still an old pickup, not a slot car. At least you were able to notice some kind of difference.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 03-10-2009, 10:17 PM   #5
67ChevyRedneck
67ChevyRedneck's Avatar
I added a 1-1/4" bar to my truck and I feel it made a big difference in higher speed cornering.
On straight road and slow turns you won't notice any difference.
It's still a full size truck, so overall, the handling wasn't that great to begin with.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-10-2009, 10:34 PM   #6
fdbdw
fdbdw's Avatar
1 1/8 havent driven it much outside taking the kids to school so maybe will notice more when I get it out on faster roads, what ya think about adding a rear bar, I realize its not a sports car just trying to do as much as I can cause my daughter says it feels like she gonna fall out when we turn left ( shes probably getting to used to her moms new charger)
Old 03-10-2009, 11:52 PM   #7
Andy4639
Old member
Andy4639's Avatar
The rear helped some as did the front. Just don't put a bigger on the back than what's up front.
Old 03-10-2009, 11:57 PM   #8
ulakovic22
As said above your results will vary with the rear bar and don't go bigger on the rear than the front. You want a little articulation in the back so your tires stay on the ground and it's easier to turn.
ulakovic22 is offline   Reply With Quote
Old 03-11-2009, 12:20 AM   #9
Gray Ghost
Gray Ghost's Avatar
In normal driving you won't notice it as much. Here's how to really get the feel of what it does.
First off it really helps if you had done this before you put it on for comparison. Drive to a parking lot and while going slowly [3-5 mph] crank the wheel in one direction or the other hard. If you don't notice the difference in a ton less body roll, you might need to have your front end checked.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 03-11-2009, 09:57 PM   #10
powell72
powell72's Avatar
Originally Posted by Andy4639 View Post
The rear hwelped some as did the front. Just don't put a bigger on the back than what's up front.
Agreed, most of the aftermarket rear bars for our trucks are 1 1/8-1 1/4''. Brothers was the only place I could find a 7/8'' rear bar. I think it was $150. I'm very happy with it.
Chris
Old 03-11-2009, 10:14 PM   #11
Andy4639
Old member
Andy4639's Avatar
I did the Camaro bar in the rear. Turned out OK I guess.
Old 03-11-2009, 10:14 PM   #12
big_al_71
big_al_71's Avatar
I installed front and rear sway bars that I bought from classic perform and I did noticed my truck handled a heck of alot better...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 03-11-2009, 10:19 PM   #13
powell72
powell72's Avatar
Here's my rear-
Chris
Old 03-14-2009, 11:25 AM   #14
fdbdw
fdbdw's Avatar
heres what i got
Old 03-14-2009, 01:22 PM   #15
67ChevyRedneck
That's different. What kit did you use? It seems to me that with the bar spaced out closer to the wheels that it would help a little more than a stock one.
If you're curious, this is what a stock one looks like with a 1-1/4" bar (stock is 1-1/8" for 1/2 tons). Mine is an ECE bar made to fit in the stock location, I think the 3/4 ton and up trucks used the 1-1/4" bar.
Jesse James
Project "On a Dime"
Old 03-14-2009, 04:30 PM   #16
fdbdw
fdbdw's Avatar
orded through LMC pg.54, #34-2510 no other info given in the catalog wasnt cheep though
Old 03-14-2009, 04:35 PM   #17
fdbdw
fdbdw's Avatar
in comparison to others it seems liket the post bushings are really compressed and angled, do you think it would be a good idea to loosen the post bolt and let the weight rest on the suspension and settle while grounded and then re-tighten
Old 03-14-2009, 05:54 PM   #18
dwcsr
Hollister Road Co.
dwcsr's Avatar
I have the same setup and it did make a big difference in driving and much bigger difference in towing. Lost a little of that coil spring soft ride but still nice.
Old 03-14-2009, 06:28 PM   #19
Andy4639
Old member
Andy4639's Avatar
That angle just doesn't look right. The way to tighten up the end links is with it on the ground and no weight on the bar it self. Did your a-arm not already have the holes in them, mine did. I see yours is on a mounted tab. I also think the fram mount is to far back toward the motor mine I think sits further forward on the flat of the frame where the hole is on yours.
Old 03-14-2009, 06:44 PM   #20
ibad57
ibad57's Avatar
Have you considered the shocks are shot causing the sway? just asking
ibad57 is offline   Reply With Quote
Old 03-14-2009, 06:48 PM   #21
ibad57
ibad57's Avatar
Will this work with air bags?
Old 03-14-2009, 10:13 PM   #22
Andy4639
Old member
Andy4639's Avatar
I wouldn't see why not. I have the helper air bags on mine. I turned it upside down to make it fit better. I also have a set of the spacers too. I asked about the size of them in another thread and was told 2" for them so I had them cut at 2" thick, they must have meant 2" total because they were way off at 2" per side so I had them cut in half.
Old 03-14-2009, 10:19 PM   #23
texanidiot25
Eat My Rust
texanidiot25's Avatar
There is no need for their to be weight on a sway bar. It's job is merely to minimize independent suspension motion when one wheel wants to go in the total opposite direction of the other... a turn. It should have little to no effect on up and down motion when the wheels are moving together. His setup is no less effective than the others pictured. Bit more strain on the end link (since it's short), but unless your bottoming out all the time, shouldn't be an issue.
texanidiot25 is offline   Reply With Quote
Old 03-14-2009, 11:33 PM   #24
Green Machine
Green Machine's Avatar
I'm sorry if you don't like my reply, but that bar just does not look right, geometry wise and how it fits and is mounted in general. If you can send it back or sell it, I would. Then check the parts board here, or one of the vendors. You should be able to get a used stock 1 1/16 bar and the correct mounts, they were used on the C10 and C20 (they were the same), for about $50. You will need to drill out 2 existing rivits in the frame to mount the stock piece. Use new grade 8 bolts and add some new poly bushings, Classic Parts of America has them for $15 and you will be good to go. We have added the stock bar with poly bushings to both of our C10 trucks and it makes a big difference.
Heres some pics of the stock bar we added on the 68 -
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 03-14-2009, 11:48 PM   #25
ulakovic22
I don't think that his bar looks that bad. The angle on the end link is because he mounted the front of the bar directly to the frame. If he spaced the bar down from the frame using the lower mounts from ECE or the stock mounts it would flatten it out so the ends were more parallel to the ground. I'm in the process of mounting mine and it sits pretty far back too on the bend. The bar actually comes really close to hitting the driver side bumper bracket. I'm going to wait though until my suspension is fully loaded before I drill the frame to mount mine.
